[mapguide-users] Filter features in the viewer
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Mon May 25 04:03:36 EDT 2009
Try this instead:
MgLayers.Filter = "FG = '3'";
map.Save();
Regards, Kenneth Skovhede, GEOGRAF A/S
vittorio skrev:
> Where can I find code examples regarding filter on the run-time layer?
> I post my code used:
> String whereClause = "FG = '3'";
> String layerNameDaFiltrare = "par10";
> MgFeatureQueryOptions queryOptions = new MgFeatureQueryOptions();
> queryOptions.SetFilter(whereClause);
> MgLayer layer = (MgLayer) map.GetLayers().GetItem(layerNameDaFiltrare);
> MgFeatureReader featureReader = layer.SelectFeatures(queryOptions);
> Thanks for your reponse.
> Vittorio.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> You must set the filter on the RuntimeLayer, not the LayerDefinition.
>> Also, look in the server log for clues.
>> There is a quirk in MapGuide, that it will render the entire layer
>> without filters, if the filter fails.
>> I'm not sure you get a log message in that case, but start out with a
>> simple filter like:
>> ID = 3
>> Vittorio Ricchiuto skrev:
>>> Hi,
>>> I would filter features in the viewer, how can I do? I filter with the
>>> web API by SetFilter, but I do not see the effect on the map
>>> although I refresh the map.
>>> Thank you for your help.
>>> Vittorio.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090525/e2e6e39f/attachment.html
