R: [mapguide-users] Filter features in the viewer
vittorio
vittorio.ricchiuto at hsh.it
Mon May 25 07:18:43 EDT 2009
MgLayers.Filter? I dont found this in the MapGuide Java API
Da: Kenneth Skovhede, GEOGRAF A/S (via Nabble)
[mailto:ml-user+64672-363962087 at n2.nabble.com]
Inviato: lunedì 25 maggio 2009 12.38
A: vittorio
Oggetto: Re: [mapguide-users] Filter features in the viewer
Try this instead:
MgLayers.Filter = "FG = '3'";
map.Save();
Regards, Kenneth Skovhede, GEOGRAF A/S
vittorio skrev:
Where can I find code examples regarding filter on the run-time layer?
I post my code used:
String whereClause = "FG = '3'";
String layerNameDaFiltrare = "par10";
MgFeatureQueryOptions queryOptions = new MgFeatureQueryOptions();
queryOptions.SetFilter(whereClause);
MgLayer layer = (MgLayer) map.GetLayers().GetItem(layerNameDaFiltrare);
MgFeatureReader featureReader = layer.SelectFeatures(queryOptions);
Thanks for your reponse.
Vittorio.
Kenneth Skovhede, GEOGRAF A/S wrote:
You must set the filter on the RuntimeLayer, not the LayerDefinition.
Also, look in the server log for clues.
There is a quirk in MapGuide, that it will render the entire layer
without filters, if the filter fails.
I'm not sure you get a log message in that case, but start out with a
simple filter like:
ID = 3
Vittorio Ricchiuto skrev:
I would filter features in the viewer, how can I do? I filter with the
web API by SetFilter, but I do not see the effect on the map
although I refresh the map.
Thank you for your help.
Vittorio.
mapguide-users mailing list
mapguide-users at ...
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2969000&i=0>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2969000&i=1>
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2969000&i=2>
_____
This email is a reply to your post @
http://n2.nabble.com/Filter-features-in-the-viewer-tp2939889p2969000.html
You can reply by email or by visting the link above.
View this message in context: http://n2.nabble.com/Filter-features-in-the-viewer-tp2939889p2969134.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090525/efe9de6b/attachment.html
