R: [mapguide-users] Filter features in the viewer
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Mon May 25 07:28:06 EDT 2009
Arh yes, my mistake.
You need to:
1) Create a copy of the LayerDefinition Xml
2) Set the <filter> property
3) Save the LayerDefinition xml as a session based resource
4) Call SetLayerDefinition to point to the session based copy
5) Save the MgMap instance
(A bit more difficult than just setting the property :))
Regards, Kenneth Skovhede, GEOGRAF A/S
vittorio skrev:
> MgLayers.Filter? I don’t found this in the MapGuide Java API
> *Da:* Kenneth Skovhede, GEOGRAF A/S (via Nabble)
> [mailto:ml-user+64672-363962087 at ...
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2969134&i=0>]
> *Inviato:* lunedì 25 maggio 2009 12.38
> *A:* vittorio
> *Oggetto:* Re: [mapguide-users] Filter features in the viewer
> Try this instead:
> MgLayers.Filter = "FG = '3'";
> map.Save();
> vittorio skrev:
> Where can I find code examples regarding filter on the run-time layer?
> I post my code used:
> String whereClause = "FG = '3'";
> String layerNameDaFiltrare = "par10";
> MgFeatureQueryOptions queryOptions = new MgFeatureQueryOptions();
> queryOptions.SetFilter(whereClause);
> MgLayer layer = (MgLayer) map.GetLayers().GetItem(layerNameDaFiltrare);
> MgFeatureReader featureReader = layer.SelectFeatures(queryOptions);
> Thanks for your reponse.
> Vittorio.
> Kenneth Skovhede, GEOGRAF A/S wrote:
> You must set the filter on the RuntimeLayer, not the LayerDefinition.
> Also, look in the server log for clues.
> There is a quirk in MapGuide, that it will render the entire layer
> without filters, if the filter fails.
> I'm not sure you get a log message in that case, but start out with a
> simple filter like:
> ID = 3
> Vittorio Ricchiuto skrev:
> Hi,
> I would filter features in the viewer, how can I do? I filter with the
> web API by SetFilter, but I do not see the effect on the map
> although I refresh the map.
> Thank you for your help.
> Vittorio.
> mapguide-users mailing list
> mapguide-users at ... <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2969000&i=0>
> mapguide-users at ... <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2969000&i=1>
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2969000&i=2>
> This email is a reply to your post @
> http://n2.nabble.com/Filter-features-in-the-viewer-tp2939889p2969000.html
> You can reply by email or by visting the link above.
> View this message in context: R: [mapguide-users] Filter features in
> the viewer
> <http://n2.nabble.com/Filter-features-in-the-viewer-tp2939889p2969134.html>
> Sent from the MapGuide Users mailing list archive
> <http://n2.nabble.com/MapGuide-Users-f1803227.html> at Nabble.com.
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090525/47dbc10e/attachment.html
