[mapguide-users] Maestro Issues
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue May 26 02:53:40 EDT 2009
Yes, both the "too large repo" issue and the "path dot" issue are
resolved in trunk.
Regards, Kenneth Skovhede, GEOGRAF A/S
Jackie Ng skrev:
> 1) I get this problem too. I have folders that contain dots and Maestro will
> just choke when it encounters one.
> 2) I do believe that this has been addressed:
> http://trac.osgeo.org/mapguide/ticket/811
> - Jackie
> Dave Wilson wrote:
>> When trying to use the 1.0.9 build of Maestro I have encountered 2
>> problems:
>> 1) Maestro bails when the repository has foreign characters in any of
>> the object (folder) names
>> 2) Maestro seemingly can't handle large repository trees (although
>> the error I encountered may be related to item 1 as I may have had foreign
>> folder names and objects)
>> ************** Exception Text **************
>> System.Exception: Failed to find node with name Épületek és kerítések
>> terept., while looking for: Library://MAV_GIS/Data/Objektumok/Épületek és
>> kerítések terept./Épület tartozékok pontszerű/
>> at OSGeo.MapGuide.Maestro.FormMain.FindParent(String resourceID)
>> at OSGeo.MapGuide.Maestro.FormMain.RebuildDocumentTree()
>> at OSGeo.MapGuide.Maestro.FormMain.FormMain_Load(Object sender,
>> EventArgs e)
>> at System.Windows.Forms.Form.OnLoad(EventArgs e)
>> at System.Windows.Forms.Form.OnCreateControl()
>> at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
>> at System.Windows.Forms.Control.CreateControl()
>> at System.Windows.Forms.Control.WmShowWindow(Message& m)
>> at System.Windows.Forms.Control.WndProc(Message& m)
>> at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
>> at System.Windows.Forms.ContainerControl.WndProc(Message& m)
>> at System.Windows.Forms.Form.WmShowWindow(Message& m)
>> at System.Windows.Forms.Form.WndProc(Message& m)
>> at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message&
>> m)
>> at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
>> at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
>> IntPtr wparam, IntPtr lparam)
>> Problem 1 was not an issue using the current preview build on the same
>> repository that generated the above error.
>> I still encountered Problem 2 on one server with a large repository with a
>> large number of folders and resources using the current preview build. I
>> think the error was basically the xml was too large. I'd have to try and
>> regenerate it for more details.
>> Regards,
>> Dave
>> Dave Wilson
>> AEC IM CRT, Calgary
>> Autodesk Canada Inc
>> Ph: 403.538.3069
>> Fax: 403.264.1442
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090526/5763cd74/attachment.html
