[mapguide-users] Maestro Issues
Jackie Ng jumpinjackie at gmail.com
Mon May 25 19:50:00 EDT 2009
1) I get this problem too. I have folders that contain dots and Maestro will
just choke when it encounters one.
2) I do believe that this has been addressed:
http://trac.osgeo.org/mapguide/ticket/811
- Jackie
Dave Wilson wrote:
> When trying to use the 1.0.9 build of Maestro I have encountered 2
> problems:
> 1)      Maestro bails when the repository has foreign characters in any of
> the object (folder) names
> 2)      Maestro seemingly can't handle large repository trees (although
> the error I encountered may be related to item 1 as I may have had foreign
> folder names and objects)
> ************** Exception Text **************
> System.Exception: Failed to find node with name Épületek és kerítések
> terept., while looking for: Library://MAV_GIS/Data/Objektumok/Épületek és
> kerítések terept./Épület tartozékok pontszerű/
>    at OSGeo.MapGuide.Maestro.FormMain.FindParent(String resourceID)
>    at OSGeo.MapGuide.Maestro.FormMain.RebuildDocumentTree()
>    at OSGeo.MapGuide.Maestro.FormMain.FormMain_Load(Object sender,
> EventArgs e)
>    at System.Windows.Forms.Form.OnLoad(EventArgs e)
>    at System.Windows.Forms.Form.OnCreateControl()
>    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
>    at System.Windows.Forms.Control.CreateControl()
>    at System.Windows.Forms.Control.WmShowWindow(Message& m)
>    at System.Windows.Forms.Control.WndProc(Message& m)
>    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
>    at System.Windows.Forms.ContainerControl.WndProc(Message& m)
>    at System.Windows.Forms.Form.WmShowWindow(Message& m)
>    at System.Windows.Forms.Form.WndProc(Message& m)
>    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message&
> m)
>    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
>    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
> IntPtr wparam, IntPtr lparam)
> Problem 1 was not an issue using the current preview build on the same
> repository that generated the above error.
> I still encountered Problem 2 on one server with a large repository with a
> large number of folders and resources using the current preview build. I
> think the error was basically the xml was too large. I'd have to try and
> regenerate it for more details.
> Regards,
> Dave
> Dave Wilson
> AEC IM CRT, Calgary
> Autodesk Canada Inc
> Ph: 403.538.3069
> Fax: 403.264.1442
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Maestro-Issues-tp2972081p2972170.html
