[mapguide-users] Maestro Issues
Dave Wilson
dave.wilson at autodesk.com
Mon May 25 19:08:12 EDT 2009
When trying to use the 1.0.9 build of Maestro I have encountered 2 problems:
1) Maestro bails when the repository has foreign characters in any of the object (folder) names
2) Maestro seemingly can't handle large repository trees (although the error I encountered may be related to item 1 as I may have had foreign folder names and objects)
************** Exception Text **************
System.Exception: Failed to find node with name Épületek és kerítések terept., while looking for: Library://MAV_GIS/Data/Objektumok/Épületek és kerítések terept./Épület tartozékok pontszerű/
at OSGeo.MapGuide.Maestro.FormMain.FindParent(String resourceID)
at OSGeo.MapGuide.Maestro.FormMain.RebuildDocumentTree()
at OSGeo.MapGuide.Maestro.FormMain.FormMain_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Problem 1 was not an issue using the current preview build on the same repository that generated the above error.
I still encountered Problem 2 on one server with a large repository with a large number of folders and resources using the current preview build. I think the error was basically the xml was too large. I'd have to try and regenerate it for more details.
Regards,
Dave
Dave Wilson
AEC IM CRT, Calgary
Autodesk Canada Inc
Ph: 403.538.3069
Fax: 403.264.1442
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090525/b4b6999f/attachment.html
