[mapguide-users] file clash with ACE.dll
Gary Morin gary.morin at keynetix.com
Thu May 28 06:25:54 EDT 2009
Hi
Yes we have developed an application that uses MapGuide and it has it own
directory and path.
We are using MGE2010. The problem occurs when the verity bin path is first
in the list.
But I just done a quick test and dropped the ACE.dll into the KeySpatial
bin directory and all seems to work ok.
Thanks
Gary
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: 28 May 2009 10:05
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] file clash with ACE.dll
how come you mapguide bin directory is in the path? are your calling
mapguide
from somewhere else hence causing path issues?
and which version of mapguide ?
I'm using CF8 and 2.0.2 / 2/1 beta without issue and with verity
z
On Thu, May 28, 2009 at 6:50 PM, Gary Morin <gary.morin at keynetix.com>
wrote:
> I have noticed a problem with an application we are developing using
> MapGuide, we often get an error while trying to invoke MapGuide
commands. In
> tracing the problem down, it seems there is a clash of file names
between
> ACE.dll in MapGuide and  ACE.dll in Verity used by Cold fusion. So if
the
> C:\CFusionMX7\verity\k2\_nti40\bin is added to the environmental path
> before the MapGuide bin directory, serious problems occur when trying to
use
> the MapGuide API.
> By putting the MapGuide Bin first, MapGuide and our application works,
but I
> don’t know what errors it will cause in Cold Fusion,  are there any
other
> workarounds?
> Many of our client still run with Coldfusion and MapGuide 6.5 so this
will
> be a common problem.
> Thanks
> Gary
> Keynetix Ltd
> Member of the Key Systems Group
> Tel. +44 (0) 1527 68888
> Fax: +44 (0) 1527 62880
> Dir. +44 (0) 1604 891152
> Mobile: 07801 371438
> Web Site: http://www.keynetix.com
> GIS for all, for the cost of a desktop GIS, www.keynetix.com/keyspatial
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
