[mapguide-users] file clash with ACE.dll
Zac Spitzer zac.spitzer at gmail.com
Thu May 28 05:05:09 EDT 2009
how come you mapguide bin directory is in the path? are your calling mapguide
from somewhere else hence causing path issues?
and which version of mapguide ?
I'm using CF8 and 2.0.2 / 2/1 beta without issue and with verity
z
On Thu, May 28, 2009 at 6:50 PM, Gary Morin <gary.morin at keynetix.com> wrote:
> I have noticed a problem with an application we are developing using
> MapGuide, we often get an error while trying to invoke MapGuide commands. In
> tracing the problem down, it seems there is a clash of file names between
> ACE.dll in MapGuide and  ACE.dll in Verity used by Cold fusion. So if the
> C:\CFusionMX7\verity\k2\_nti40\bin is added to the environmental path
> before the MapGuide bin directory, serious problems occur when trying to use
> the MapGuide API.
> By putting the MapGuide Bin first, MapGuide and our application works, but I
> don’t know what errors it will cause in Cold Fusion,  are there any other
> workarounds?
> Many of our client still run with Coldfusion and MapGuide 6.5 so this will
> be a common problem.
> Thanks
> Gary
> Keynetix Ltd
> Member of the Key Systems Group
> Tel. +44 (0) 1527 68888
> Fax: +44 (0) 1527 62880
> Dir. +44 (0) 1604 891152
> Mobile: 07801 371438
> Web Site: http://www.keynetix.com
> GIS for all, for the cost of a desktop GIS, www.keynetix.com/keyspatial
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
