[mapguide-users] Add Data Connection for Shp's Problem
Martin Morrison martin.morrison at edsi.com
Thu May 28 16:18:58 EDT 2009
You also need at minimum the shx....
Martin
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Thursday, May 28, 2009 4:19 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Add Data Connection for Shp's Problem
At a minimum you need the shp and the dbf file. The shx and idx files are index files. MGOS will create whichever it needs if they are missing.
cpg files are the codepage of the language the dbf is written in.
The prj file contains the coordinate system information and should always be included whenever possible, otherwise the user has to manually do an override and get the correct coordinate system.
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
Sent: Thursday, May 28, 2009 1:53 PM
Subject: Re: [mapguide-users] Add Data Connection for Shp's Problem
I don't know Shape that well, but generally, just add all of them.
Regards, Kenneth Skovhede, GEOGRAF A/S
Tom Lazo skrev:
> Ok, i have a dbf, idx, sbn, sbx, shp, shp.xml, shx. Which of these files
> should i set.
> Thanks.
> Tom
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
