[mapguide-users] Add Data Connection for Shp's Problem
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu May 28 15:52:22 EDT 2009
This is the Maestro user guide, and the only one I know of:
http://trac.osgeo.org/mapguide/wiki/maestro/UserGuides/FileFeatureSource
To add manually:
When you add the file, choose the "All files" in the file type.
Then mark all the files that are related to the shp, and click OK.
After you are done all the files should be uploaded.
Select the .shp file and click the star button.
Regards, Kenneth Skovhede, GEOGRAF A/S
Tom Lazo skrev:
> Thanks, i'll try to do it as you said. But, if it doesn't work, could you
> tell me how could i do it manually, is there any tutorial for that?.
> Thanks again
> Tom
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> You need to upload more than just the .shp file.
>> There are usually a bunch of files related to a single shape file,
>> and you need to upload them all (they all have the same filename, but
>> different extensions).
>> The Maestro UI was not really helpfull there, so I changed it.
>> You can either use your current version of Maestro, and add the files
>> manually,
>> or use the newest preview version and it will ask you if you want it
>> done automatically.
>> (new version released a few hours ago r3911):
>> http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
>> Tom Lazo skrev:
>>> Hi all,
>>> Well, i've tried to "Upload Data into a new Feature Source" via mapguide,
>>> but the link throws me to a "Not found" page. Ok... i've realized this
>>> problems some weeks before.. so i got the AutoDesk MapGuide Studio
>>> 2009...trial.. ok. Actually this frameworks allows me to upload the data
>>> from a shape file.
>>> Ok, now i'm trying to do the same but with Maestro, so i go to
>>> file->new->Data Connection->OSGeo FDO Provider for SHP... then i search
>>> my
>>> shape file and open it.
>>> Now, i validate this resource whith the big green check and i get this
>>> error:
>>> Validating file:
>>> Session:08df1c68-2d35-102c-8000-001cc0a62e16_es_7F0000010AFC0AFB0AFA//6d899f62-7b06-4fb3-8f53-d8e9b2187049.FeatureSource
>>> Error - OSGeo.MapGuide.MaestroAPI.FeatureSource: Failed to read schema
>>> description: Error en el servidor remoto: (559)
>>> MgInvalidStreamHeaderException.:
>>> Invalid stream header exception.
>>> Exception occurred in method MgCommand.GetResponse at line 152 in file
>>> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\mapguidecommon\Services/Command.cpp
>>> Plz, tell what's the cause of this mistake...i'm really lost.
>>> Thanks
>>> Tom
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090528/a08f4690/attachment.html
