[mapguide-users] Add Data Connection for Shp's Problem
Pedro Venâncio pedrongvenancio at yahoo.com
Thu May 28 18:23:23 EDT 2009
Hi Kenneth
Adding shp files automatically with newer version of Maestro makes the .dbf file as the datasource (file in bold), instead of .shp file. Is this correct? I have to say that everything woks fine anyway.
Thanks for your work!
Regards,
Pedro Venancio
--- On Thu, 5/28/09, Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk> wrote:
From: Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>
Subject: Re: [mapguide-users] Add Data Connection for Shp's Problem
To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
Date: Thursday, May 28, 2009, 8:52 PM
This is the Maestro user guide, and the only one I know of:
http://trac.osgeo.org/mapguide/wiki/maestro/UserGuides/FileFeatureSource
To add manually:
When you add the file, choose the "All files" in the file type.
Then mark all the files that are related to the shp, and click OK.
After you are done all the files should be uploaded.
Select the .shp file and click the star button.
Regards, Kenneth Skovhede, GEOGRAF A/S
Tom Lazo skrev:
  Thanks, i'll try to do it as you said. But, if it doesn't work, could you
tell me how could i do it manually, is there any tutorial for that?.
Thanks again
Tom
Kenneth Skovhede, GEOGRAF A/S wrote:
    You need to upload more than just the .shp file.
There are usually a bunch of files related to a single shape file,
and you need to upload them all (they all have the same filename, but
different extensions).
The Maestro UI was not really helpfull there, so I changed it.
You can either use your current version of Maestro, and add the files
manually,
or use the newest preview version and it will ask you if you want it
done automatically.
(new version released a few hours ago r3911):
http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
Tom Lazo skrev:
      Hi all,
Well, i've tried to "Upload Data into a new Feature Source" via mapguide,
but the link throws me to a "Not found" page. Ok... i've realized this
problems some weeks before.. so i got the AutoDesk MapGuide Studio
2009...trial.. ok. Actually this frameworks allows me to upload the data
from a shape file.
Ok, now i'm trying to do the same but with Maestro, so i go to
file->new->Data Connection->OSGeo FDO Provider for SHP... then i search
my
shape file and open it.
Now, i validate this resource whith the big green check and i get this
error:
Validating file:
Session:08df1c68-2d35-102c-8000-001cc0a62e16_es_7F0000010AFC0AFB0AFA//6d899f62-7b06-4fb3-8f53-d8e9b2187049.FeatureSource
Error - OSGeo.MapGuide.MaestroAPI.FeatureSource: Failed to read schema
description: Error en el servidor remoto: (559)
MgInvalidStreamHeaderException.:
Invalid stream header exception.
Exception occurred in method MgCommand.GetResponse at line 152 in file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\mapguidecommon\Services/Command.cpp
Plz, tell what's the cause of this mistake...i'm really lost.
Thanks
Tom
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
-----Inline Attachment Follows-----
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090528/6630c65c/attachment.html
