[mapguide-users] Add Data Connection for Shp's Problem
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Fri May 29 02:47:47 EDT 2009
I don't think that the .dbf file should be in bold, but if it works, it
works :).
Regards, Kenneth Skovhede, GEOGRAF A/S
Pedro Venâncio skrev:
> Hi Kenneth
> Adding shp files automatically with newer version of Maestro makes the
> .dbf file as the datasource (file in bold), instead of .shp file. Is
> this correct? I have to say that everything woks fine anyway.
> Thanks for your work!
> Regards,
> Pedro Venancio
> --- On *Thu, 5/28/09, Kenneth Skovhede, GEOGRAF A/S /<ks at geograf.dk>/*
> wrote:
> From: Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>
> Subject: Re: [mapguide-users] Add Data Connection for Shp's Problem
> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
> Date: Thursday, May 28, 2009, 8:52 PM
> This is the Maestro user guide, and the only one I know of:
> http://trac.osgeo.org/mapguide/wiki/maestro/UserGuides/FileFeatureSource
> To add manually:
> When you add the file, choose the "All files" in the file type.
> Then mark all the files that are related to the shp, and click OK.
> After you are done all the files should be uploaded.
> Select the .shp file and click the star button.
> Tom Lazo skrev:
>> Thanks, i'll try to do it as you said. But, if it doesn't work, could you
>> tell me how could i do it manually, is there any tutorial for that?.
>> Thanks again
>> Tom
>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>> You need to upload more than just the .shp file.
>>> There are usually a bunch of files related to a single shape file,
>>> and you need to upload them all (they all have the same filename, but
>>> different extensions).
>>> The Maestro UI was not really helpfull there, so I changed it.
>>> You can either use your current version of Maestro, and add the files
>>> manually,
>>> or use the newest preview version and it will ask you if you want it
>>> done automatically.
>>> (new version released a few hours ago r3911):
>>> http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
>>> Tom Lazo skrev:
>>>> Hi all,
>>>> Well, i've tried to "Upload Data into a new Feature Source" via mapguide,
>>>> but the link throws me to a "Not found" page. Ok... i've realized this
>>>> problems some weeks before.. so i got the AutoDesk MapGuide Studio
>>>> 2009...trial.. ok. Actually this frameworks allows me to upload the data
>>>> from a shape file.
>>>> Ok, now i'm trying to do the same but with Maestro, so i go to
>>>> file->new->Data Connection->OSGeo FDO Provider for SHP... then i search
>>>> my
>>>> shape file and open it.
>>>> Now, i validate this resource whith the big green check and i get this
>>>> error:
>>>> Validating file:
>>>> Session:08df1c68-2d35-102c-8000-001cc0a62e16_es_7F0000010AFC0AFB0AFA//6d899f62-7b06-4fb3-8f53-d8e9b2187049.FeatureSource
>>>> Error - OSGeo.MapGuide.MaestroAPI.FeatureSource: Failed to read schema
>>>> description: Error en el servidor
>>>> remoto: (559)
>>>> MgInvalidStreamHeaderException.:
>>>> Invalid stream header exception.
>>>> Exception occurred in method MgCommand.GetResponse at line 152 in file
>>>> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\mapguidecommon\Services/Command.cpp
>>>> Plz, tell what's the cause of this mistake...i'm really lost.
>>>> Thanks
>>>> Tom
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> -----Inline Attachment Follows-----
> </mc/compose?to=mapguide-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090529/3a09f64e/attachment.html
