[mapguide-users] Mapguide Centos and FDO trouble isntalling
Remco Houtkamp
r.houtkamp at burohoutkamp.nl
Wed Nov 4 05:16:28 EST 2009
Zac, I'm trying to install Mapguide 2.0.2
Met vriendelijke groet,
Remco Houtkamp
BURO HOUTKAMP
|T: 06 14 390 205 |E: r.houtkamp at burohoutkamp.nl |P: Kweldergras 21,
1441 WP, Purmerend |
Van: mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org] Namens Zac Spitzer
Verzonden: woensdag 4 november 2009 10:36
Aan: MapGuide Users Mail List
Onderwerp: Re: [mapguide-users] Mapguide Centos and FDO trouble
isntalling
which version of MG are you trying to build?
On Wed, Nov 4, 2009 at 8:16 PM, Remco Houtkamp
<r.houtkamp at burohoutkamp.nl> wrote:
Hi list,
After being unsuccesfull trying to connect a winxp installation to
postgis I switched to linux. It is really hard, because I don't know te
basics. After a few days my knowledge of linux improved a little. I
think I know why I can not install Mapguide to Centos5. I get this
message:
In file included from Band.h:21,
from Band.cpp:20:
Stylization.h:77:17: error: Fdo.h: No such file or directory
Stylization.h:78:33: error: FdoExpressionEngine.h: No such file or
directory
Stylization.h:79:51: error: FdoExpressionEngineFunctionCollection.h: No
Stylization.h:80:54: error: FdoExpressionEngineINonAggregateFunction.h:
Stylization.h:85: error: 'FDO_ACTIVELONGTRANSACTION' was not declared in
this scope
Stylization.h:86: error: 'FDO_ROOTLONGTRANSACTION' was not declared in
this scope
GridData.h:54: error: 'FdoString' has not been declared
LineBuffer.h:85: error: 'FdoDimensionality' has not been declared
LineBuffer.h:115: error: 'FdoDimensionality' has not been declared
LineBuffer.h:122: error: 'FdoDimensionality' does not name a type
LineBuffer.h:193: error: 'FdoDimensionality' does not name a type
LineBuffer.h:85: error: 'FdoDimensionality_XY' was not declared in this
scope
LineBuffer.h:115: error: 'FdoDimensionality_XY' was not declared in this
scope
LineBuffer.h:244: error: 'FdoDimensionality' has not been declared
LineBuffer.h:244: error: 'FdoDimensionality_XY' was not declared in this
scope
make[2]: *** [Band.lo] Fout 1
make[2]: Map '/root/Desktop/mapguide-2.0.2/Common/Stylization' wordt
verlaten
make[1]: *** [all-recursive] Fout 1
make[1]: Map '/root/Desktop/mapguide-2.0.2/Common' wordt verlaten
make: *** [all-recursive] Fout 1
So there is a FDO problem. I installed FDO 3.4.0 using svn checkout
http://svn.osgeo.org/fdo/tags/3.4.0/ fdo-3.4.0 (adjustment from this
tutorial http://wiki.osgeo.org/wiki/Building_MapGuide_on_CentOS_5 )
The documentation tells me I've to specify the fdo location when
installing mapguide. I tried to do this by ./configure
--with-fdo-include= IncludeDir --with-fdo-lib= LibDir which I altered to
./configure --with-fdo-include= /usr/local/fdo-3.4.0 --with-fdo-lib=
/usr/local/fdo-3.4.0/lib
What is it I'm doing wrong? Is it ok that /usr/local/fdo-3.4.0 is empty
except for the map lib? the map lib does contain files.
Thanks in advance.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091104/cd0c6d8f/attachment.html
