[mapguide-users] Mapguide Centos and FDO trouble isntalling
Zac Spitzer zac.spitzer at gmail.com
Wed Nov 4 05:20:30 EST 2009
i think FDO 3.2 is the right version of FDO... 3.4 is for 2.1
On Wed, Nov 4, 2009 at 9:16 PM, Remco Houtkamp
<r.houtkamp at burohoutkamp.nl>wrote:
>  Zac, I’m trying to install Mapguide 2.0.2
> Met vriendelijke groet,
> Remco Houtkamp
> *BURO HOUTKAMP*
> |T: 06 14 390 205 |E: r.houtkamp at burohoutkamp.nl |P:  Kweldergras 21, 1441
> WP, Purmerend |
> *Van:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *Namens *Zac Spitzer
> *Verzonden:* woensdag 4 november 2009 10:36
> *Aan:* MapGuide Users Mail List
> *Onderwerp:* Re: [mapguide-users] Mapguide Centos and FDO trouble
> isntalling
> which version of MG are you trying to build?
> On Wed, Nov 4, 2009 at 8:16 PM, Remco Houtkamp <r.houtkamp at burohoutkamp.nl>
> wrote:
> Hi list,
> After being unsuccesfull trying to connect a winxp installation to postgis
> I switched to linux. It is really hard, because I don't know te basics.
> After a few days my knowledge of linux improved a little. I think I know why
> I can not install Mapguide to Centos5. I get this message:
> In file included from Band.h:21,
>                 from Band.cpp:20:
> Stylization.h:77:17: error: Fdo.h: No such file or directory
> Stylization.h:78:33: error: FdoExpressionEngine.h: No such file or
> directory
> Stylization.h:79:51: error: FdoExpressionEngineFunctionCollection.h: No
> Stylization.h:80:54: error: FdoExpressionEngineINonAggregateFunction.h: No
> Stylization.h:85: error: 'FDO_ACTIVELONGTRANSACTION' was not declared in
> this scope
> Stylization.h:86: error: 'FDO_ROOTLONGTRANSACTION' was not declared in this
> scope
> GridData.h:54: error: 'FdoString' has not been declared
> LineBuffer.h:85: error: 'FdoDimensionality' has not been declared
> LineBuffer.h:115: error: 'FdoDimensionality' has not been declared
> LineBuffer.h:122: error: 'FdoDimensionality' does not name a type
> LineBuffer.h:193: error: 'FdoDimensionality' does not name a type
> LineBuffer.h:85: error: 'FdoDimensionality_XY' was not declared in this
> scope
> LineBuffer.h:115: error: 'FdoDimensionality_XY' was not declared in this
> scope
> LineBuffer.h:244: error: 'FdoDimensionality' has not been declared
> LineBuffer.h:244: error: 'FdoDimensionality_XY' was not declared in this
> scope
> make[2]: *** [Band.lo] Fout 1
> make[2]: Map '/root/Desktop/mapguide-2.0.2/Common/Stylization' wordt
> verlaten
> make[1]: *** [all-recursive] Fout 1
> make[1]: Map '/root/Desktop/mapguide-2.0.2/Common' wordt verlaten
> make: *** [all-recursive] Fout 1
> So there is a FDO problem. I installed FDO 3.4.0 using svn checkout
> http://svn.osgeo.org/fdo/tags/3.4.0/ fdo-3.4.0 (adjustment from this
> tutorial http://wiki.osgeo.org/wiki/Building_MapGuide_on_CentOS_5 )
> The documentation tells me I've to specify the fdo location when installing
> mapguide. I tried to do this by ./configure --with-fdo-include= IncludeDir
> --with-fdo-lib= LibDir which I altered to ./configure --with-fdo-include=
> /usr/local/fdo-3.4.0 --with-fdo-lib= /usr/local/fdo-3.4.0/lib
> What is it I'm doing wrong? Is it ok that /usr/local/fdo-3.4.0 is empty
> except for the map lib? the map lib does contain files.
> Thanks in advance.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
Zac Spitzer
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091104/ce65dc92/attachment.html
