[mapguide-users] totally new to MG
Nitin Chaturvedi
nitincv at gmail.com
Thu Nov 5 07:43:01 EST 2009
Thanks a ton Kenneth,
I've done that already...
& thanks to you I'm able to create my Map with shape files....... but
again its through Maestro & I can browse the map through it only. I
need to know how to change the map in the sample application as it
continues to display Sheboygan data.
secondly I have VS2005. If we discard the website method. Kindly
elaborate how to go about it.
thanks a Ton again U're gr8 (I'm actually exited to see the map with
shape files and now eager to use it on my own application)!!!
On Thu, Nov 5, 2009 at 1:54 PM, Kenneth Skovhede, GEOGRAF A/S
<ks at geograf.dk> wrote:
> If you have MapGuide Enterprise, you also have MapGuide Studio.
> If you have either MapGuide Enterprise or MapGuideOpenSource,
> you can try MapGuide Maestro:
> http://trac.osgeo.org/mapguide/wiki/maestro
> Either tool can help you set up a map.
> If you are starting 100% from scratch, you can install the sample data
> package (called Sheboygan):
> http://mapguide.osgeo.org/download/releases/2.0.x-samples
> Once you have a WebLayout working in Studio/Maestro, you can click the
> "Preview" button.
> This will show you the map in a working environment.
> This environment is also a sample of how to develop such an application!
> All the code for the various actions can be found in:
> C:\Program Files\MapGuideOpenSource\Web\www\
> (If you want to develop .Net applications, you must select the .Net API
> during the install process).
> To start developing an application, you bascially create a new .Net Web
> Solution.
> Carefull: don't use the "WebSite" method, as that is intended for CMS like
> solutions,
> and very hard to get working with MapGuide. Unfortunately this is default
> with VS2005.
> The Web solution must use IIS, not the internal development server,
> configureable from the
> project properties. If the "Web" tab is missing, or is missing the "Servers"
> section, you have the
> wrong type of "Web site".
> Next, copy all dll's from MapGuide into the "bin" folder in your project.
> The dll's are located here:
> C:\Program Files\MapGuideOpenSource\WebExtensions\www\mapviewernet\bin
> Then add a reference to the MapGuideDotNetApi.dll.
> You can now access all the Mg* objects.
> See the aspx files for samples:
> C:\Program Files\MapGuideOpenSource\WebExtensions\www\mapviewernet\*.aspx
> More samples here:
> http://trac.osgeo.org/mapguide/wiki/CodeSamples
> And make sure you read the FAQ:
> http://trac.osgeo.org/mapguide/wiki/CodeSamples/AspDotNet/DevFAQ
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Nitin Chaturvedi skrev:
>> Hi everyone,
>> I'm totally new to MG. I'm trying to understand and develop a small
>> web application using .net and .SHP files. I've been reading all the
>> documentation provided with MG and have understood about the 3 tiers.
>> But unable to understand how to develop an application in .net I tried
>> to work on the sample applications provided with MG installer (windows
>> & IIS) but they are giving a lot of reference errors.
>> I need help BIG Time......
>> It would be really helpful if someone could provide me with a simple
>> "working" .net code which shows map, and options to zoom in/out, pan
>> and get info of features.
>> Thanks in advance !!
>> Warm Regards,
>> Nitin
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
