[mapguide-users] totally new to MG
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Nov 5 03:24:44 EST 2009
If you have MapGuide Enterprise, you also have MapGuide Studio.
If you have either MapGuide Enterprise or MapGuideOpenSource,
you can try MapGuide Maestro:
http://trac.osgeo.org/mapguide/wiki/maestro
Either tool can help you set up a map.
If you are starting 100% from scratch, you can install the sample data
package (called Sheboygan):
http://mapguide.osgeo.org/download/releases/2.0.x-samples
Once you have a WebLayout working in Studio/Maestro, you can click the
"Preview" button.
This will show you the map in a working environment.
This environment is also a sample of how to develop such an application!
All the code for the various actions can be found in:
C:\Program Files\MapGuideOpenSource\Web\www\
(If you want to develop .Net applications, you must select the .Net API
during the install process).
To start developing an application, you bascially create a new .Net Web
Solution.
Carefull: don't use the "WebSite" method, as that is intended for CMS
like solutions,
and very hard to get working with MapGuide. Unfortunately this is
default with VS2005.
The Web solution must use IIS, not the internal development server,
configureable from the
project properties. If the "Web" tab is missing, or is missing the
"Servers" section, you have the
wrong type of "Web site".
Next, copy all dll's from MapGuide into the "bin" folder in your project.
The dll's are located here:
C:\Program Files\MapGuideOpenSource\WebExtensions\www\mapviewernet\bin
Then add a reference to the MapGuideDotNetApi.dll.
You can now access all the Mg* objects.
See the aspx files for samples:
C:\Program Files\MapGuideOpenSource\WebExtensions\www\mapviewernet\*.aspx
More samples here:
http://trac.osgeo.org/mapguide/wiki/CodeSamples
And make sure you read the FAQ:
http://trac.osgeo.org/mapguide/wiki/CodeSamples/AspDotNet/DevFAQ
Regards, Kenneth Skovhede, GEOGRAF A/S
Nitin Chaturvedi skrev:
> Hi everyone,
> I'm totally new to MG. I'm trying to understand and develop a small
> web application using .net and .SHP files. I've been reading all the
> documentation provided with MG and have understood about the 3 tiers.
> But unable to understand how to develop an application in .net I tried
> to work on the sample applications provided with MG installer (windows
> & IIS) but they are giving a lot of reference errors.
> I need help BIG Time......
> It would be really helpful if someone could provide me with a simple
> "working" .net code which shows map, and options to zoom in/out, pan
> and get info of features.
> Thanks in advance !!
> Warm Regards,
> Nitin
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
