[mapguide-users] totally new to MG
Nitin Chaturvedi
nitincv at gmail.com
Mon Nov 9 01:38:57 EST 2009
I'd surely post the screenshot in a while!
but at the moment can you tell me how to set the new map that I've
created using Maestro?
I'm getting only the Shebogyan map in my samples. if I view it by
browsing through maestro the map appears perfectly, but if I browse
MAIN.aspx its showing shebogyan :(
How to change the source of the map? Thr new map is created using shape files !
Help awaited !! :(
2009/11/6 Ivan Miličević <Ivan.Milicevic at supranet.hr>:
> Could you post a screen or error details?
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Nitin Chaturvedi
> Sent: Friday, November 06, 2009 1:12 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] totally new to MG
> Hi kenneth,
> My simple sole purpose is to show data of an area (delhi) and show
> point of interests and provide the user with options to do various
> kinds of search on those POIs. Thanks to your guidance I've created a
> new map and added layers of delhi (shape Files). Now I'm stuck at the
> coding part.
> I'm getting errors in the dotnetsamples application and don't know how
> to display the map of delhi in my own application. However when I
> browse the through Maestro the map is coming perfectly with the themes
> that I've applied.
> don't know head or tail of what to do and where to start ! :)
> thanks for your help !!!!
> Nitin
> On Thu, Nov 5, 2009 at 7:44 PM, Kenneth Skovhede, GEOGRAF A/S
> <ks at geograf.dk> wrote:
>> If you have VS2005, I think the SP1 installs the "original" Web method as a
>> "Web Solution".
>> I can't really remember how to get around it, as I have VS 2008 now.
>> You usually don't "change the map", rather, you start with another map,
>> which you can then modify.
>> If you want to see how to modify the map during runtime, there are some
>> examples for using the MaestroAPI here:
>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI
>> You can do the same using the regular API, although the class names, etc.
>> are different.
>> The two examples "Adding a layer before startup via Maestro API" and
>> "Modifying the filter on a layer"
>> are good examples for understanding where to plug into MapGuide.
>> Could you try to explain a specific task that you need to perform?
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> Nitin Chaturvedi skrev:
>> Thanks a ton Kenneth,
>> I've done that already...
>> & thanks to you I'm able to create my Map with shape files....... but
>> again its through Maestro & I can browse the map through it only. I
>> need to know how to change the map in the sample application as it
>> continues to display Sheboygan data.
>> secondly I have VS2005. If we discard the website method. Kindly
>> elaborate how to go about it.
>> thanks a Ton again U're gr8 (I'm actually exited to see the map with
>> shape files and now eager to use it on my own application)!!!
>> On Thu, Nov 5, 2009 at 1:54 PM, Kenneth Skovhede, GEOGRAF A/S
>> If you have MapGuide Enterprise, you also have MapGuide Studio.
>> If you have either MapGuide Enterprise or MapGuideOpenSource,
>> you can try MapGuide Maestro:
>> Either tool can help you set up a map.
>> If you are starting 100% from scratch, you can install the sample data
>> package (called Sheboygan):
>> http://mapguide.osgeo.org/download/releases/2.0.x-samples
>> Once you have a WebLayout working in Studio/Maestro, you can click the
>> "Preview" button.
>> This will show you the map in a working environment.
>> This environment is also a sample of how to develop such an application!
>> All the code for the various actions can be found in:
>> C:\Program Files\MapGuideOpenSource\Web\www\
>> (If you want to develop .Net applications, you must select the .Net API
>> during the install process).
>> To start developing an application, you bascially create a new .Net Web
>> Solution.
>> Carefull: don't use the "WebSite" method, as that is intended for CMS like
>> solutions,
>> and very hard to get working with MapGuide. Unfortunately this is default
>> with VS2005.
>> The Web solution must use IIS, not the internal development server,
>> configureable from the
>> project properties. If the "Web" tab is missing, or is missing the "Servers"
>> section, you have the
>> wrong type of "Web site".
>> Next, copy all dll's from MapGuide into the "bin" folder in your project.
>> The dll's are located here:
>> C:\Program Files\MapGuideOpenSource\WebExtensions\www\mapviewernet\bin
>> Then add a reference to the MapGuideDotNetApi.dll.
>> You can now access all the Mg* objects.
>> See the aspx files for samples:
>> C:\Program Files\MapGuideOpenSource\WebExtensions\www\mapviewernet\*.aspx
>> More samples here:
>> http://trac.osgeo.org/mapguide/wiki/CodeSamples
>> And make sure you read the FAQ:
>> http://trac.osgeo.org/mapguide/wiki/CodeSamples/AspDotNet/DevFAQ
>> Hi everyone,
>> I'm totally new to MG. I'm trying to understand and develop a small
>> web application using .net and .SHP files. I've been reading all the
>> documentation provided with MG and have understood about the 3 tiers.
>> But unable to understand how to develop an application in .net I tried
>> to work on the sample applications provided with MG installer (windows
>> & IIS) but they are giving a lot of reference errors.
>> I need help BIG Time......
>> It would be really helpful if someone could provide me with a simple
>> "working" .net code which shows map, and options to zoom in/out, pan
>> and get info of features.
>> Thanks in advance !!
>> Warm Regards,
>> Nitin
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
