[mapguide-users] totally new to MG
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Mon Nov 9 06:40:57 EST 2009
If you read up on the samples for the Maestro API, you should notice a
redirect (last line):
http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/AddInitialLayer
The redirect looks like this:
Response.Redirect("/mapguide/ajaxviewer/?LAYOUT=" & Server.UrlEncode(tempWebLayout) & "&SESSION=" & Server.UrlEncode(con.SessionID), true)
For this to work, simply set the tempWebLayout variable to point at your
map.
You don't need the SessionID for starters, you can just add:
&USERNAME=Anonymous&PASSWORD=
So you get:
Response.Redirect("/mapguide/ajaxviewer/?LAYOUT=" & Server.UrlEncode(tempWebLayout) & "&USERNAME=Anonymous&PASSWORD=", true)
What code is inside the file main.aspx that you mention?
Regards, Kenneth Skovhede, GEOGRAF A/S
Nitin Chaturvedi skrev:
> I'd surely post the screenshot in a while!
> but at the moment can you tell me how to set the new map that I've
> created using Maestro?
> I'm getting only the Shebogyan map in my samples. if I view it by
> browsing through maestro the map appears perfectly, but if I browse
> MAIN.aspx its showing shebogyan :(
> How to change the source of the map? Thr new map is created using shape files !
> Help awaited !! :(
> 2009/11/6 Ivan Miličević <Ivan.Milicevic at supranet.hr>:
>> Could you post a screen or error details?
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Nitin Chaturvedi
>> Sent: Friday, November 06, 2009 1:12 PM
>> To: MapGuide Users Mail List
>> Subject: Re: [mapguide-users] totally new to MG
>> Hi kenneth,
>> My simple sole purpose is to show data of an area (delhi) and show
>> point of interests and provide the user with options to do various
>> kinds of search on those POIs. Thanks to your guidance I've created a
>> new map and added layers of delhi (shape Files). Now I'm stuck at the
>> coding part.
>> I'm getting errors in the dotnetsamples application and don't know how
>> to display the map of delhi in my own application. However when I
>> browse the through Maestro the map is coming perfectly with the themes
>> that I've applied.
>> don't know head or tail of what to do and where to start ! :)
>> thanks for your help !!!!
>> Nitin
>> On Thu, Nov 5, 2009 at 7:44 PM, Kenneth Skovhede, GEOGRAF A/S
>> <ks at geograf.dk> wrote:
>>> If you have VS2005, I think the SP1 installs the "original" Web method as a
>>> "Web Solution".
>>> I can't really remember how to get around it, as I have VS 2008 now.
>>> You usually don't "change the map", rather, you start with another map,
>>> which you can then modify.
>>> If you want to see how to modify the map during runtime, there are some
>>> examples for using the MaestroAPI here:
>>> You can do the same using the regular API, although the class names, etc.
>>> are different.
>>> The two examples "Adding a layer before startup via Maestro API" and
>>> "Modifying the filter on a layer"
>>> are good examples for understanding where to plug into MapGuide.
>>> Could you try to explain a specific task that you need to perform?
>>> Thanks a ton Kenneth,
>>> I've done that already...
>>> & thanks to you I'm able to create my Map with shape files....... but
>>> again its through Maestro & I can browse the map through it only. I
>>> need to know how to change the map in the sample application as it
>>> continues to display Sheboygan data.
>>> secondly I have VS2005. If we discard the website method. Kindly
>>> elaborate how to go about it.
>>> thanks a Ton again U're gr8 (I'm actually exited to see the map with
>>> shape files and now eager to use it on my own application)!!!
>>> On Thu, Nov 5, 2009 at 1:54 PM, Kenneth Skovhede, GEOGRAF A/S
>>> If you have MapGuide Enterprise, you also have MapGuide Studio.
>>> If you have either MapGuide Enterprise or MapGuideOpenSource,
>>> you can try MapGuide Maestro:
>>> Either tool can help you set up a map.
>>> If you are starting 100% from scratch, you can install the sample data
>>> package (called Sheboygan):
>>> http://mapguide.osgeo.org/download/releases/2.0.x-samples
>>> Once you have a WebLayout working in Studio/Maestro, you can click the
>>> "Preview" button.
>>> This will show you the map in a working environment.
>>> This environment is also a sample of how to develop such an application!
>>> All the code for the various actions can be found in:
>>> C:\Program Files\MapGuideOpenSource\Web\www\
>>> (If you want to develop .Net applications, you must select the .Net API
>>> during the install process).
>>> To start developing an application, you bascially create a new .Net Web
>>> Solution.
>>> Carefull: don't use the "WebSite" method, as that is intended for CMS like
>>> solutions,
>>> and very hard to get working with MapGuide. Unfortunately this is default
>>> with VS2005.
>>> The Web solution must use IIS, not the internal development server,
>>> configureable from the
>>> project properties. If the "Web" tab is missing, or is missing the "Servers"
>>> section, you have the
>>> wrong type of "Web site".
>>> Next, copy all dll's from MapGuide into the "bin" folder in your project.
>>> The dll's are located here:
>>> C:\Program Files\MapGuideOpenSource\WebExtensions\www\mapviewernet\bin
>>> Then add a reference to the MapGuideDotNetApi.dll.
>>> You can now access all the Mg* objects.
>>> See the aspx files for samples:
>>> C:\Program Files\MapGuideOpenSource\WebExtensions\www\mapviewernet\*.aspx
>>> More samples here:
>>> http://trac.osgeo.org/mapguide/wiki/CodeSamples
>>> And make sure you read the FAQ:
>>> http://trac.osgeo.org/mapguide/wiki/CodeSamples/AspDotNet/DevFAQ
>>> Hi everyone,
>>> I'm totally new to MG. I'm trying to understand and develop a small
>>> web application using .net and .SHP files. I've been reading all the
>>> documentation provided with MG and have understood about the 3 tiers.
>>> But unable to understand how to develop an application in .net I tried
>>> to work on the sample applications provided with MG installer (windows
>>> & IIS) but they are giving a lot of reference errors.
>>> I need help BIG Time......
>>> It would be really helpful if someone could provide me with a simple
>>> "working" .net code which shows map, and options to zoom in/out, pan
>>> and get info of features.
>>> Thanks in advance !!
>>> Warm Regards,
>>> Nitin
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091109/a80fa9fa/attachment.html
