[mapguide-users] Problem with MrSid in Maestro(1.1) - Mapguide 2.1
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Nov 9 03:06:27 EST 2009
The warning tells you that the provider reports the default extents,
which are probably not valid.
Either your data is missing extent info (not likely) or the
provider is not working.
Please see the FdoGdalNotes for info on how to debug rasters:
http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
Regards, Kenneth Skovhede, GEOGRAF A/S
HABC skrev:
> I have been trying to get the raster image to work but with no luck. I have
> downloaded the plugin. I don't know what i have missed. Couple things i
> notice: when i try to save a raster dataconnect the message comes up like
> this "Spatial context extent appeas to be invalid(or default)". I did set up
> coord override. Other thing is in the config file has something like this:
>             <Feature name="CA272">
>               <Band name="RGB" number="1">
>                 <Image frame="1" name="CA272.sid">
>                   <Bounds>
>                     <MinX>-10000000</MinX>
>                     <MinY>-10000000</MinY>
>                     <MaxX>10000000</MaxX>
>                     <MaxY>10000000</MaxY>
>                   </Bounds>
>                 </Image>
>               </Band>
>             </Feature>
>             <Feature name="CA273">
>                 <Image frame="1" name="CA273.sid">
>                   <Bounds>
>                   </Bounds>
>                 </Image>
>               </Band>
>             </Feature>
> Please help!!
> HABC
