[mapguide-users] Problem with MrSid in Maestro(1.1) - Mapguide 2.1
Dejan Gregor dejan.gregor at gmail.com
Mon Nov 9 03:54:33 EST 2009
Dear Kenneth and HABC,
is MrSID really supported my MGOS 2.1 out of the box by the GDAL provider
that comes with the installation? Personally, I was not able to run it.
HABC, which provider do you use for MrSID? How did you implementi it to MGOS
2.1?
Dejan
On Mon, Nov 9, 2009 at 09:06, Kenneth Skovhede, GEOGRAF A/S
<ks at geograf.dk>wrote:
> The warning tells you that the provider reports the default extents,
> which are probably not valid.
> Either your data is missing extent info (not likely) or the
> provider is not working.
> Please see the FdoGdalNotes for info on how to debug rasters:
> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
> Regards, Kenneth Skovhede, GEOGRAF A/S
> HABC skrev:
>> I have been trying to get the raster image to work but with no luck. I
>> have
>> downloaded the plugin. I don't know what i have missed. Couple things i
>> notice: when i try to save a raster dataconnect the message comes up like
>> this "Spatial context extent appeas to be invalid(or default)". I did set
>> up
>> coord override. Other thing is in the config file has something like this:
>>            <Feature name="CA272">
>>              <Band name="RGB" number="1">
>>                <Image frame="1" name="CA272.sid">
>>                  <Bounds>
>>                    <MinX>-10000000</MinX>
>>                    <MinY>-10000000</MinY>
>>                    <MaxX>10000000</MaxX>
>>                    <MaxY>10000000</MaxY>
>>                  </Bounds>
>>                </Image>
>>              </Band>
>>            </Feature>
>>            <Feature name="CA273">
>>                <Image frame="1" name="CA273.sid">
>>                  <Bounds>
>>                  </Bounds>
>>                </Image>
>>              </Band>
>>            </Feature>
>> Please help!!
>> HABC
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091109/ef4c3a0c/attachment.html
