[mapguide-users] Problem with MrSid in Maestro(1.1) - Mapguide 2.1
Crispin_at_1Spatial crispin.hoult at 1spatial.com
Mon Nov 9 04:32:45 EST 2009
Also see...
http://n2.nabble.com/Minutes-from-PSC-Meeting-Nov-5-09-tt3954905.html#a3962451
... MapGuide bugs 1121 and 790 (=FDO 493)
They well maybe all the same thing...
 Crispin
Dejan Gregor wrote:
> Dear Kenneth and HABC,
> is MrSID really supported my MGOS 2.1 out of the box by the GDAL provider
> that comes with the installation? Personally, I was not able to run it.
> HABC, which provider do you use for MrSID? How did you implementi it to
> MGOS
> 2.1?
> Dejan
> On Mon, Nov 9, 2009 at 09:06, Kenneth Skovhede, GEOGRAF A/S
> <ks at geograf.dk>wrote:
>> The warning tells you that the provider reports the default extents,
>> which are probably not valid.
>> Either your data is missing extent info (not likely) or the
>> provider is not working.
>> Please see the FdoGdalNotes for info on how to debug rasters:
>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> HABC skrev:
>>> I have been trying to get the raster image to work but with no luck. I
>>> have
>>> downloaded the plugin. I don't know what i have missed. Couple things i
>>> notice: when i try to save a raster dataconnect the message comes up
>>> like
>>> this "Spatial context extent appeas to be invalid(or default)". I did
>>> set
>>> up
>>> coord override. Other thing is in the config file has something like
>>> this:
>>>            <Feature name="CA272">
>>>              <Band name="RGB" number="1">
>>>                <Image frame="1" name="CA272.sid">
>>>                  <Bounds>
>>>                    <MinX>-10000000</MinX>
>>>                    <MinY>-10000000</MinY>
>>>                    <MaxX>10000000</MaxX>
>>>                    <MaxY>10000000</MaxY>
>>>                  </Bounds>
>>>                </Image>
>>>              </Band>
>>>            </Feature>
>>>            <Feature name="CA273">
>>>                <Image frame="1" name="CA273.sid">
>>>                  <Bounds>
>>>                  </Bounds>
>>>                </Image>
>>>              </Band>
>>>            </Feature>
>>> Please help!!
>>> HABC
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Problem-with-MrSid-in-Maestro-1-1-Mapguide-2-1-tp3964578p3972022.html
