[mapguide-users] Inser feature problem
mighty_duck
msiljegovic at gmail.com
Mon Nov 9 04:01:07 EST 2009
I dont think it is Oracle error, it inserts everything correcly to database,
problem start when FeatureService wants to return "information" that feature
is succesufully inserted into the database.
Wouldn't it be maybe FDO problem?!
thanks
Dejan Gregor wrote:
> What is the ORA error/exception number?
> Dejan
> On Mon, Nov 9, 2009 at 09:42, mighty_duck <msiljegovic at gmail.com> wrote:
>> Hi,
>> I created table in Oracle with two columns: ID(primary key) and
>> Geometry(SDO_GEOMETRY). I also done all stuffs with metadata and spatial
>> index.....
>> Problem is when I want to insert feature into the table...
>> featureService.UpdateFeatures(resourceIdentifier, commandCollection,
>> false);. This command correctly inserts new feature into the table, but
>> throws also exception depending if I specify ID directly (Feature service
>> exception - error occurred while insert operation, no ID to retrieve), or
>> I
>> let Oracle autogenerates the new ID(An unclassified exception occurred).
>> So in both cases feature is inserted into the table, but everytime I get
>> exception, and I cant realize what cause this problem!!!
>> thanks in advance
>> View this message in context:
>> http://n2.nabble.com/Inser-feature-problem-tp3971827p3971827.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Inser-feature-problem-tp3971827p3971881.html
