[mapguide-users] Inser feature problem
Dejan Gregor dejan.gregor at gmail.com
Mon Nov 9 03:55:58 EST 2009
What is the ORA error/exception number?
Dejan
On Mon, Nov 9, 2009 at 09:42, mighty_duck <msiljegovic at gmail.com> wrote:
> Hi,
> I created table in Oracle with two columns: ID(primary key) and
> Geometry(SDO_GEOMETRY). I also done all stuffs with metadata and spatial
> index.....
> Problem is when I want to insert feature into the table...
> featureService.UpdateFeatures(resourceIdentifier, commandCollection,
> false);. This command correctly inserts new feature into the table, but
> throws also exception depending if I specify ID directly (Feature service
> exception - error occurred while insert operation, no ID to retrieve), or I
> let Oracle autogenerates the new ID(An unclassified exception occurred).
> So in both cases feature is inserted into the table, but everytime I get
> exception, and I cant realize what cause this problem!!!
> thanks in advance
> http://n2.nabble.com/Inser-feature-problem-tp3971827p3971827.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091109/088dd5d9/attachment.html
