[mapguide-users] Inser feature problem
mighty_duck
msiljegovic at gmail.com
Mon Nov 9 04:05:07 EST 2009
zspitzer wrote:
> which provider are you using?
> On Mon, Nov 9, 2009 at 8:01 PM, mighty_duck <msiljegovic at gmail.com> wrote:
>> I dont think it is Oracle error, it inserts everything correcly to
>> database,
>> problem start when FeatureService wants to return "information" that
>> feature
>> is succesufully inserted into the database.
>> Wouldn't it be maybe FDO problem?!
>> thanks
>> Dejan Gregor wrote:
>>> What is the ORA error/exception number?
>>> Dejan
>>> On Mon, Nov 9, 2009 at 09:42, mighty_duck <msiljegovic at gmail.com> wrote:
>>>> Hi,
>>>> I created table in Oracle with two columns: ID(primary key) and
>>>> Geometry(SDO_GEOMETRY). I also done all stuffs with metadata and
>>>> spatial
>>>> index.....
>>>> Problem is when I want to insert feature into the table...
>>>> featureService.UpdateFeatures(resourceIdentifier, commandCollection,
>>>> false);. This command correctly inserts new feature into the table, but
>>>> throws also exception depending if I specify ID directly (Feature
>>>> service
>>>> exception - error occurred while insert operation, no ID to retrieve),
>>>> or
>>>> I
>>>> let Oracle autogenerates the new ID(An unclassified exception
>>>> occurred).
>>>> So in both cases feature is inserted into the table, but everytime I
>>>> get
>>>> exception, and I cant realize what cause this problem!!!
>>>> thanks in advance
>>>> View this message in context:
>>>> http://n2.nabble.com/Inser-feature-problem-tp3971827p3971827.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> http://n2.nabble.com/Inser-feature-problem-tp3971827p3971881.html
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
View this message in context: http://n2.nabble.com/Inser-feature-problem-tp3971827p3971901.html
