[mapguide-users] Inser feature problem
Dejan Gregor
dejan.gregor at gmail.com
Mon Nov 9 04:07:10 EST 2009
mighty_duck,
you have several Oracle FDO providers and versions (check
http://fdo.osgeo.org/OSProviderOverviews.html). Which one (name, version)
are you using?
Dejan
On Mon, Nov 9, 2009 at 10:05, mighty_duck <msiljegovic at gmail.com> wrote:
> FDO
> zspitzer wrote:
> > which provider are you using?
> > On Mon, Nov 9, 2009 at 8:01 PM, mighty_duck <msiljegovic at gmail.com>
> wrote:
> >> I dont think it is Oracle error, it inserts everything correcly to
> >> database,
> >> problem start when FeatureService wants to return "information" that
> >> feature
> >> is succesufully inserted into the database.
> >> Wouldn't it be maybe FDO problem?!
> >> thanks
> >> Dejan Gregor wrote:
> >>> What is the ORA error/exception number?
> >>> Dejan
> >>> On Mon, Nov 9, 2009 at 09:42, mighty_duck <msiljegovic at gmail.com>
> wrote:
> >>>> Hi,
> >>>> I created table in Oracle with two columns: ID(primary key) and
> >>>> Geometry(SDO_GEOMETRY). I also done all stuffs with metadata and
> >>>> spatial
> >>>> index.....
> >>>> Problem is when I want to insert feature into the table...
> >>>> featureService.UpdateFeatures(resourceIdentifier, commandCollection,
> >>>> false);. This command correctly inserts new feature into the table,
> but
> >>>> throws also exception depending if I specify ID directly (Feature
> >>>> service
> >>>> exception - error occurred while insert operation, no ID to retrieve),
> >>>> or
> >>>> I
> >>>> let Oracle autogenerates the new ID(An unclassified exception
> >>>> occurred).
> >>>> So in both cases feature is inserted into the table, but everytime I
> >>>> get
> >>>> exception, and I cant realize what cause this problem!!!
> >>>> thanks in advance
> >>>> View this message in context:
> >>>> http://n2.nabble.com/Inser-feature-problem-tp3971827p3971827.html
> >>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> >>>> _______________________________________________
> >>>> mapguide-users mailing list
> >>>> mapguide-users at lists.osgeo.org
> >>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> >> http://n2.nabble.com/Inser-feature-problem-tp3971827p3971881.html
> > Zac Spitzer
> > Solution Architect / Director
> > Ennoble Consultancy Australia
> > http://www.ennoble.com.au
> > http://zacster.blogspot.com
> > +61 405 847 168
> http://n2.nabble.com/Inser-feature-problem-tp3971827p3971901.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091109/fed1b6fe/attachment.html
