[mapguide-users] Hot to set MgProperty to NULL
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Nov 10 02:37:35 EST 2009
SetNull() is the method to use.
I've found that various providers either break on, or ignore, null values.
Regards, Kenneth Skovhede, GEOGRAF A/S
Gunter Becker skrev:
> Hi,
> I'd like to update existing features with NULL values.
> Let's say I have a property called 'age' and I want to delete the value of
> this property
> so that I have a null value instead of the integer value.
> The only contructor I've found needs two parameters. The property name and
> the property value.
> The property value can't be null:
> MgInt16Property newProperty = new MgInt16Property(propertyName,
> Convert.ToInt16(propertyValue));
> There is a SetNull-Methode which I can set to 'true' afterwards. But this
> doesn't affect anything.
> Any idea on how to update a property with a null value???
> Thanks Gunter
