[mapguide-users] Windows 7 Install with 2.1 Beta
Kori Maleski kori.maleski at gmail.com
Tue Nov 10 18:07:03 EST 2009
Should be the same - as 7 is pretty much the same as Vista.
Both use IIS7 - so the web server will be the same.
On Tue, Nov 10, 2009 at 3:48 PM, Flipper <scotth at mpowerinnovations.com>wrote:
> Had no problem on 64bit Vista...Hmmm Got the 7 disk here and don't wanna
> wipe
> out my laptop to find I have to wipe it out again to go back to
> vista...Dang
> wish someone knew
> If I get brave I'll let people Know...Won't be this week though.
> Jason Birch wrote:
> > No idea. The installer isn't 64-bit aware, so doesn't work out of the box
> > on
> > 64bit installs.
> > You'll have to at a minimum (if it works) manually set your app pool to
> > run
> > in 32bit mode.  If that's even possible on 7 - does it allow multiple app
> > pools?
> > Other potential pitfalls may include UAC and DEP.
> > Jason
> > 2009/11/10 Flipper <scotth at mpowerinnovations.com>
> >> Not seeing any info on installing 2.1 beta on Windows 7 64 bit machine.
> >> Does anyone know if it works...if so Is it the same steps as Vista 64
> >> bit?
> >> View this message in context:
> http://n2.nabble.com/Windows-7-Install-with-2-1-Beta-tp3982905p3982905.html
> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
> >> _______________________________________________
> >> mapguide-users mailing list
> >> mapguide-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://n2.nabble.com/Windows-7-Install-with-2-1-Beta-tp3982905p3983132.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091110/f89f510d/attachment.html
