[mapguide-users] Windows 7 Install with 2.1 Beta
Rock Beans
rockbeans at gmail.com
Mon Nov 16 12:05:01 EST 2009
It works on Windows 7 64bit but you may need to tweak IIS settings
within the APP Pool to allow 32apps. I think the installer already
does this by creating a mapguide APP Pool though.
On Tue, Nov 10, 2009 at 5:07 PM, Kori Maleski <kori.maleski at gmail.com> wrote:
> Should be the same - as 7 is pretty much the same as Vista.
> Both use IIS7 - so the web server will be the same.
> On Tue, Nov 10, 2009 at 3:48 PM, Flipper <scotth at mpowerinnovations.com>
> wrote:
>> Had no problem on 64bit Vista...Hmmm Got the 7 disk here and don't wanna
>> wipe
>> out my laptop to find I have to wipe it out again to go back to
>> vista...Dang
>> wish someone knew
>> If I get brave I'll let people Know...Won't be this week though.
>> Jason Birch wrote:
>> > No idea. The installer isn't 64-bit aware, so doesn't work out of the
>> > box
>> > on
>> > 64bit installs.
>> > You'll have to at a minimum (if it works) manually set your app pool to
>> > run
>> > in 32bit mode. If that's even possible on 7 - does it allow multiple
>> > app
>> > pools?
>> > Other potential pitfalls may include UAC and DEP.
>> > Jason
>> > 2009/11/10 Flipper <scotth at mpowerinnovations.com>
>> >> Not seeing any info on installing 2.1 beta on Windows 7 64 bit machine.
>> >> Does anyone know if it works...if so Is it the same steps as Vista 64
>> >> bit?
>> >> View this message in context:
>> >> http://n2.nabble.com/Windows-7-Install-with-2-1-Beta-tp3982905p3982905.html
>> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> >> _______________________________________________
>> >> mapguide-users mailing list
>> >> mapguide-users at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> http://n2.nabble.com/Windows-7-Install-with-2-1-Beta-tp3982905p3983132.html
