[mapguide-users] RE: Permissions for Administrator
Dave Wilson dave.wilson at autodesk.com
Thu Nov 12 11:47:57 EST 2009
Did you check the error logs and the system event log to see if something obvious is recorded? Sometimes on a server the advanced security configuration causes a problem. Have you checked in IIS to see if the Web Extensions for PHP, the MapAgent ISAPI and .NET are enabled ?
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Langen, Gido
Sent: Thursday, November 12, 2009 8:11 AM
To: MapGuide Users Mail List
Subject: [mapguide-users] Permissions for Administrator
I have installed and setup MapGuide Enterprise 2010 on my PC using IIS and PHP (localhost).  It worked like a charm.  I also tried to install the software on a server.  But I cannot even login as an Administrator.  Right after the LOGIN page, I get immediately an HTTP 500 error.  I have installed the software repeatedly with the same result.  It seems to me that I might not have all required permissions.  Though I have administrator privileges on the server.  Does anybody know what the problem might be?
Thanks,
Gido
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091112/e6b54896/attachment.html
