[mapguide-users] RE: Permissions for Administrator
Langen, Gido
Gido.Langen at NRCan-RNCan.gc.ca
Fri Nov 13 10:18:12 EST 2009
Hi Dave,
Your help got me in the right direction, but I still couldn't get it to
work.
Thank so much,
Gido
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: November 12, 2009 09:48
To: MapGuide Users Mail List
Subject: [mapguide-users] RE: Permissions for Administrator
Did you check the error logs and the system event log to see if
something obvious is recorded? Sometimes on a server the advanced
security configuration causes a problem. Have you checked in IIS to see
if the Web Extensions for PHP, the MapAgent ISAPI and .NET are enabled ?
Dave
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Langen,
Gido
Sent: Thursday, November 12, 2009 8:11 AM
Subject: [mapguide-users] Permissions for Administrator
I have installed and setup MapGuide Enterprise 2010 on my PC using IIS
and PHP (localhost). It worked like a charm. I also tried to install
the software on a server. But I cannot even login as an Administrator.
Right after the LOGIN page, I get immediately an HTTP 500 error. I have
installed the software repeatedly with the same result. It seems to me
that I might not have all required permissions. Though I have
administrator privileges on the server. Does anybody know what the
problem might be?
Thanks,
Gido
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091113/5e7d9239/attachment.html
