[mapguide-users] RE: Permissions for Administrator
Zac Spitzer
zac.spitzer at gmail.com
Fri Nov 13 19:39:27 EST 2009
try editing your php.ini config and enable display_errors
On Sat, Nov 14, 2009 at 2:18 AM, Langen, Gido
<Gido.Langen at nrcan-rncan.gc.ca> wrote:
> Hi Dave,
> Your help got me in the right direction, but I still couldn't get it to
> work.
> Thank so much,
> Gido
> ________________________________
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
> Sent: November 12, 2009 09:48
> To: MapGuide Users Mail List
> Subject: [mapguide-users] RE: Permissions for Administrator
> Did you check the error logs and the system event log to see if something
> obvious is recorded? Sometimes on a server the advanced security
> configuration causes a problem. Have you checked in IIS to see if the Web
> Extensions for PHP, the MapAgent ISAPI and .NET are enabled ?
> Dave
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Langen, Gido
> Sent: Thursday, November 12, 2009 8:11 AM
> Subject: [mapguide-users] Permissions for Administrator
> I have installed and setup MapGuide Enterprise 2010 on my PC using IIS and
> PHP (localhost). It worked like a charm. I also tried to install the
> software on a server. But I cannot even login as an Administrator. Right
> after the LOGIN page, I get immediately an HTTP 500 error. I have installed
> the software repeatedly with the same result. It seems to me that I might
> not have all required permissions. Though I have administrator privileges
> on the server. Does anybody know what the problem might be?
> Thanks,
> Gido
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
