[mapguide-users] Permissions for Administrator
Jason Birch
jason at jasonbirch.com
Fri Nov 13 22:56:06 EST 2009
Yeah... And startup errors...
I think I remember seeing this problem when the php session save
directory wasn't writable, or something like that?
On 2009-11-13, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> try editing your php.ini config and enable display_errors
> On Sat, Nov 14, 2009 at 2:18 AM, Langen, Gido
> <Gido.Langen at nrcan-rncan.gc.ca> wrote:
>> Hi Dave,
>> Your help got me in the right direction, but I still couldn't get it to
>> work.
>> Thank so much,
>> Gido
>> ________________________________
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
>> Sent: November 12, 2009 09:48
>> To: MapGuide Users Mail List
>> Subject: [mapguide-users] RE: Permissions for Administrator
>> Did you check the error logs and the system event log to see if something
>> obvious is recorded? Sometimes on a server the advanced security
>> configuration causes a problem. Have you checked in IIS to see if the Web
>> Extensions for PHP, the MapAgent ISAPI and .NET are enabled ?
>> Dave
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Langen, Gido
>> Sent: Thursday, November 12, 2009 8:11 AM
>> Subject: [mapguide-users] Permissions for Administrator
>> I have installed and setup MapGuide Enterprise 2010 on my PC using IIS and
>> PHP (localhost). It worked like a charm. I also tried to install the
>> software on a server. But I cannot even login as an Administrator. Right
>> after the LOGIN page, I get immediately an HTTP 500 error. I have
>> installed
>> the software repeatedly with the same result. It seems to me that I might
>> not have all required permissions. Though I have administrator privileges
>> on the server. Does anybody know what the problem might be?
>> Thanks,
>> Gido
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
