[mapguide-users] Creation mapdefinition using Maestro
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Nov 16 04:00:25 EST 2009
Generally, you should use the same coordinate system on your map as your
data has (best performance).
However, WGS 84 is a world spanning coordinate system
(latitude/longitude), and
might be a "fallback" because the provider is unable to detect the
correct coordinate system.
Regards, Kenneth Skovhede, GEOGRAF A/S
sathishpsk9 skrev:
> Hi every one ,
> While creating a resource, we have option Coordinate System overrides, --
> what it means ?
> In that we have a option to fetch coordinate system found in
> featuresource.... when i click this i get following.....
> Source
> Target
> OracleSrid32643
> PROJCS["WGS 84 / UTM zone 43N", GEOGCS
> [ "WGS 84", DATUM ["World GeodeticSystem              1984 (EPSG ID 6326)",
> SPHEROID ["WGS 84 (EPSG ID 7030)", 6378137, 298.257223563]], PRIMEM [
> "Greenwich", 0.000000 ], UNIT ["Decimal Degree", 0.01745329251994328]],
> PROJECTION ["UTM zone 43N (EPSG OP 16043)"], PARAMETER
> ["Latitude_Of_Origin", 0], PARAMETER ["Central_Meridian",
> 75.00000000000000000000000000000000000029], PARAMETER ["Scale_Factor",
> .9996], PARAMETER ["False_Easting", 500000], PARAMETER ["False_Northing",
> 0], UNIT ["Meter", 1]]
> Again while creating mapresource fram a layer defintion ..
> we have a option --Coordinate system  -----------------
> what should i fill there ( i have given just spatial table ......i don know
> much about spatial tables otr data  )
> Thanks
> Satish
