[mapguide-users] Creation mapdefinition using Maestro
sathishpsk9 sathishpsk9 at gmail.com
Mon Nov 16 02:25:44 EST 2009
Hi every one ,
While creating a resource, we have option Coordinate System overrides, --
what it means ?
In that we have a option to fetch coordinate system found in
featuresource.... when i click this i get following.....
Source
Target
OracleSrid32643
PROJCS["WGS 84 / UTM zone 43N", GEOGCS
[ "WGS 84", DATUM ["World GeodeticSystem              1984 (EPSG ID 6326)",
SPHEROID ["WGS 84 (EPSG ID 7030)", 6378137, 298.257223563]], PRIMEM [
"Greenwich", 0.000000 ], UNIT ["Decimal Degree", 0.01745329251994328]],
PROJECTION ["UTM zone 43N (EPSG OP 16043)"], PARAMETER
["Latitude_Of_Origin", 0], PARAMETER ["Central_Meridian",
75.00000000000000000000000000000000000029], PARAMETER ["Scale_Factor",
.9996], PARAMETER ["False_Easting", 500000], PARAMETER ["False_Northing",
0], UNIT ["Meter", 1]]
Again while creating mapresource fram a layer defintion ..
we have a option --Coordinate system  -----------------
what should i fill there ( i have given just spatial table ......i don know
much about spatial tables otr data  )
Thanks
Satish
View this message in context: http://n2.nabble.com/Creation-mapdefinition-using-Maestro-tp4010662p4010662.html
