[mapguide-users] Selection Problem in 'New Window'
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Nov 17 03:15:01 EST 2009
Try listing all the POST and GET variable to see if the SESSION variable
is missing.
If it is missing, you have to look through ajaxmappane.temp and figure
out where it gets lost.
Regards, Kenneth Skovhede, GEOGRAF A/S
NISHA P skrev:
> Hi Kenneth,
> I activated New Window by selecting 'Feature hyperlink target' as 'New
> Window (In maestro layout)..The query builder is
> successfully got in taskpane...But in new window that error is shown..
> On Mon, Nov 16, 2009 at 2:27 PM, Kenneth Skovhede, GEOGRAF A/S
> <ks at geograf.dk <mailto:ks at geograf.dk>> wrote:
>     Not sure how you activate the "new window", but the error message
>     means that the session id
>     that you passed to the page is invalid (i'm guessing that it is
>     missing).
>     NISHA P skrev:
>>     Hi All
>>     I have made a query builder in my application..The query builder
>>     is working in the following manner..
>>     I created a new tool in the toolbar..When i click the tool,
>>     multiple combo box is appeared in the task pane..
>>     When I select particular combination from the combo box, the
>>     corresponding area is highlighted in the map..
>>     The query builder works fine in the taskpane..But the problem is
>>     when i develop the same query bulder in
>>     'New Window' (instead of task pane) the following error occurs..
>>     Invalid argument(s): [1] = "" The session ID is invalid because
>>     the session separator character was not found.Invalid
>>     argument(s): [1] = "" The session ID is invalid because the
>>     session separator character was not found. Exception occurred in
>>     method MgUserInformation.SetMgSessionId at line 183 in file
>>     d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\mapguidecommon\System/UserInformation.cpp
>>     Thanks and Regards
>>     Nisha
>>     _______________________________________________ mapguide-users
>>     mailing list mapguide-users at lists.osgeo.org
>>     <mailto:mapguide-users at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
>     mapguide-users mailing list
>     mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> Nisha
> nisha at iiitmk.ac.in <mailto:nisha at iiitmk.ac.in>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091117/8af0ee29/attachment.html
