[mapguide-users] Selection Problem in 'New Window'
NISHA P
nishap97 at gmail.com
Tue Nov 17 00:31:38 EST 2009
Hi Kenneth,
I activated New Window by selecting 'Feature hyperlink target' as 'New
Window (In maestro layout)..The query builder is
successfully got in taskpane...But in new window that error is shown..
On Mon, Nov 16, 2009 at 2:27 PM, Kenneth Skovhede, GEOGRAF A/S <
ks at geograf.dk> wrote:
> Not sure how you activate the "new window", but the error message means
> that the session id
> that you passed to the page is invalid (i'm guessing that it is missing).
> Regards, Kenneth Skovhede, GEOGRAF A/S
> NISHA P skrev:
> Hi All
> I have made a query builder in my application..The query builder is working
> in the following manner..
> I created a new tool in the toolbar..When i click the tool, multiple combo
> box is appeared in the task pane..
> When I select particular combination from the combo box, the corresponding
> area is highlighted in the map..
> The query builder works fine in the taskpane..But the problem is when i
> develop the same query bulder in
> 'New Window' (instead of task pane) the following error occurs..
> Invalid argument(s): [1] = "" The session ID is invalid because the session
> separator character was not found.Invalid argument(s): [1] = "" The session
> ID is invalid because the session separator character was not found.
> Exception occurred in method MgUserInformation.SetMgSessionId at line 183 in
> file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\mapguidecommon\System/UserInformation.cpp
> Thanks and Regards
> Nisha
> mapguide-users mailing listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
Nisha
nisha at iiitmk.ac.in
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091117/05efeb5e/attachment.html
