[mapguide-users] Selection Problem in 'New Window'
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Mon Nov 16 03:57:27 EST 2009
Not sure how you activate the "new window", but the error message means
that the session id
that you passed to the page is invalid (i'm guessing that it is missing).
Regards, Kenneth Skovhede, GEOGRAF A/S
NISHA P skrev:
> Hi All
> I have made a query builder in my application..The query builder is
> working in the following manner..
> I created a new tool in the toolbar..When i click the tool, multiple
> combo box is appeared in the task pane..
> When I select particular combination from the combo box, the
> corresponding area is highlighted in the map..
> The query builder works fine in the taskpane..But the problem is when
> i develop the same query bulder in
> 'New Window' (instead of task pane) the following error occurs..
> Invalid argument(s): [1] = "" The session ID is invalid because the
> session separator character was not found.Invalid argument(s): [1] =
> "" The session ID is invalid because the session separator character
> was not found. Exception occurred in method
> MgUserInformation.SetMgSessionId at line 183 in file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\mapguidecommon\System/UserInformation.cpp
> Thanks and Regards
> Nisha
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091116/cb080c0b/attachment.html
