[mapguide-users] GETMAPIMAGE vs GETDYNAMICMAPOVERLAYIMAGE and out of memory issue
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Nov 17 03:59:03 EST 2009
GETDYNAMICMAPOVERLAYIMAGE only returns the dynamic layers,
where GETMAPIMAGE returns all layers.
If you have no baselayers (aka tiled layers) you will not see any
difference.
I have generated images with over 5000x10000 pixels with no memory issues.
Try adding the clip=1 parameter to the call to see if it makes a difference.
Also, small scales tend to increase memory usage, especially without the
clip parameter.
Regards, Kenneth Skovhede, GEOGRAF A/S
cagray skrev:
> Hi,
> I am trying to generate images by mimicing the calls done in the AJAX map
> viewer. I notice that in the ajaxmappane.templ it only ever uses
> GETDYNAMICMAPOVERLAYIMAGE. I was wondering what the difference was from just
> using GETMAPIMAGE?
> Also if I try and do images over 1024 by 1024 I always get an out of memory
> error returned. Is there any way around this such as a setting in the
> server.config? Sometimes I even get an out of memory for 1024 by 1024
> depending on the map and have to reduce it do 512 by 512. Any thoughts?
> Thanks
> Colin
