[mapguide-users] Map Inconsistencies. Is it a Network\Server Issue??
durrrr paul.nicholson at capita.co.uk
Tue Nov 17 04:03:51 EST 2009
Yes it does. I'm not sure if it resolves all of the issue, however it
definately speeds things up and reduces the inconsistencies..
Are there any complications with upgrading? Is it a simple process?
Thanks
zspitzer wrote:
> yep, rasters are finally fixed in 2.1...  2.1 is a darn good release,
> lots a good fixes in there
> as a test, if you remove the raster layers does it solve your problem?
> z
View this message in context: http://n2.nabble.com/Map-Inconsistencies-Is-it-a-Network-Server-Issue-tp3998668p4017359.html
