[mapguide-users] Map Inconsistencies. Is it a Network\Server Issue??
Zac Spitzer zac.spitzer at gmail.com
Tue Nov 17 04:00:02 EST 2009
yep, rasters are finally fixed in 2.1...  2.1 is a darn good release,
lots a good fixes in there
as a test, if you remove the raster layers does it solve your problem?
z
On Tue, Nov 17, 2009 at 7:57 PM, durrrr <paul.nicholson at capita.co.uk> wrote:
> Hi,
> We are using version 2.0 could that be the cause of any of the issues?
> zspitzer wrote:
> > what version are you using? it's bug reporting 101 to quote the version
> > number :)
> > if your using less than 2.1, rasters will always break mapguide os
> > try the 2.1 beta if you not already, it's a big improvement on anything
> > before it
> > On Tue, Nov 17, 2009 at 1:43 AM, durrrr <paul.nicholson at capita.co.uk>
> > wrote:
> >> Hi,
> >> Thanks for your reply.
> >> I have added some details from my server setup. Do these numbers look
> ok?
> >> General Properties
> >> TCP/IP maximum transmission unit:  1460
> >> Connection timeout (seconds):  120
> >> Connection timer interval (seconds): 60
> >> Client Connection Properties
> >> Maximum connections:  100
> >> Maximum queued operations:  40
> >> Maximum threads in pool: 20
> >> Site Connection Properties
> >> Maximum connections:  20
> >> Maximum queued operations:  20
> >> Maximum threads in pool: 10
> >> Thanks
> >> Durrrr
> >> Kenneth Skovhede, GEOGRAF A/S wrote:
> >> > It sounds as if you are exhausting some resource.
> >> > One guess is that you are maxing out your connectionpool, so the FDO
> >> > provider locks up.
> >> > Another possibility is that your provider is using too many
> >> filehandles,
> >> > and then stops working.
> >> > For both the possibilities, try limiting the number of connection pool
> >> > entries in the serverconfig.ini,
> >> > and see if the problem gets better or worse (raising the limit is
> >> likely
> >> > a bad solution).
> >> > Regards, Kenneth Skovhede, GEOGRAF A/S
> >> > durrrr skrev:
> >> >> Hi,
> >> >> We are having a great deal of difficulties with the consistency of
> >> >> layers,
> >> >> points and searches on our map.
> >> >> It seems works perfectly 10 times but then suddenly things stop
> >> working
> >> >> such
> >> >> as search's or suddenly the map wont display at all.
> >> >> Because these issues are intermittent i can think of no other
> >> explanation
> >> >> other than slow network\Server.
> >> >> Currently we have a map with 55 layers (os, raster, point, line) it
> is
> >> >> running on a Windows server using Apache, we have a seperate server
> >> for
> >> >> our
> >> >> maps and it is being viewed over the internet.
> >> >> If anyone can help or suggest anything i would appreciate it!
> >> >> (I am relativly new to the whole mapping development role so
> >> simplified
> >> >> questions are appreciated!)
> >> >> Thanks in advance
> >> > _______________________________________________
> >> > mapguide-users mailing list
> >> > mapguide-users at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> >> View this message in context:
> http://n2.nabble.com/Map-Inconsistencies-Is-it-a-Network-Server-Issue-tp3998668p4012377.html
> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
> > Zac Spitzer
> > Solution Architect / Director
> > Ennoble Consultancy Australia
> > http://www.ennoble.com.au
> > http://zacster.blogspot.com
> > +61 405 847 168
> http://n2.nabble.com/Map-Inconsistencies-Is-it-a-Network-Server-Issue-tp3998668p4017333.html
Zac Spitzer
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091117/664992f3/attachment.html
