[mapguide-users] Map Inconsistencies. Is it a Network\Server
Issue??
durrrr
paul.nicholson at capita.co.uk
Tue Nov 17 03:57:05 EST 2009
We are using version 2.0 could that be the cause of any of the issues?
zspitzer wrote:
> what version are you using? it's bug reporting 101 to quote the version
> number :)
> if your using less than 2.1, rasters will always break mapguide os
> try the 2.1 beta if you not already, it's a big improvement on anything
> before it
> On Tue, Nov 17, 2009 at 1:43 AM, durrrr <paul.nicholson at capita.co.uk>
> wrote:
>> Hi,
>> Thanks for your reply.
>> I have added some details from my server setup. Do these numbers look ok?
>> General Properties
>> TCP/IP maximum transmission unit: 1460
>> Connection timeout (seconds): 120
>> Connection timer interval (seconds): 60
>> Client Connection Properties
>> Maximum connections: 100
>> Maximum queued operations: 40
>> Maximum threads in pool: 20
>> Site Connection Properties
>> Maximum connections: 20
>> Maximum queued operations: 20
>> Maximum threads in pool: 10
>> Thanks
>> Durrrr
>> Kenneth Skovhede, GEOGRAF A/S wrote:
>> > It sounds as if you are exhausting some resource.
>> > One guess is that you are maxing out your connectionpool, so the FDO
>> > provider locks up.
>> > Another possibility is that your provider is using too many
>> filehandles,
>> > and then stops working.
>> > For both the possibilities, try limiting the number of connection pool
>> > entries in the serverconfig.ini,
>> > and see if the problem gets better or worse (raising the limit is
>> likely
>> > a bad solution).
>> > Regards, Kenneth Skovhede, GEOGRAF A/S
>> > durrrr skrev:
>> >> Hi,
>> >> We are having a great deal of difficulties with the consistency of
>> >> layers,
>> >> points and searches on our map.
>> >> It seems works perfectly 10 times but then suddenly things stop
>> working
>> >> such
>> >> as search's or suddenly the map wont display at all.
>> >> Because these issues are intermittent i can think of no other
>> explanation
>> >> other than slow network\Server.
>> >> Currently we have a map with 55 layers (os, raster, point, line) it is
>> >> running on a Windows server using Apache, we have a seperate server
>> for
>> >> our
>> >> maps and it is being viewed over the internet.
>> >> If anyone can help or suggest anything i would appreciate it!
>> >> (I am relativly new to the whole mapping development role so
>> simplified
>> >> questions are appreciated!)
>> >> Thanks in advance
>> > _______________________________________________
>> > mapguide-users mailing list
>> > mapguide-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://n2.nabble.com/Map-Inconsistencies-Is-it-a-Network-Server-Issue-tp3998668p4012377.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
View this message in context: http://n2.nabble.com/Map-Inconsistencies-Is-it-a-Network-Server-Issue-tp3998668p4017333.html
