[mapguide-users] Map Inconsistencies. Is it a Network\Server Issue??
Zac Spitzer zac.spitzer at gmail.com
Mon Nov 16 18:54:15 EST 2009
what version are you using? it's bug reporting 101 to quote the version
number :)
if your using less than 2.1, rasters will always break mapguide os
try the 2.1 beta if you not already, it's a big improvement on anything
before it
On Tue, Nov 17, 2009 at 1:43 AM, durrrr <paul.nicholson at capita.co.uk> wrote:
> Hi,
> Thanks for your reply.
> I have added some details from my server setup. Do these numbers look ok?
> General Properties
> TCP/IP maximum transmission unit:  1460
> Connection timeout (seconds):  120
> Connection timer interval (seconds): 60
> Client Connection Properties
> Maximum connections:  100
> Maximum queued operations:  40
> Maximum threads in pool: 20
> Site Connection Properties
> Maximum connections:  20
> Maximum queued operations:  20
> Maximum threads in pool: 10
> Thanks
> Durrrr
> Kenneth Skovhede, GEOGRAF A/S wrote:
> > It sounds as if you are exhausting some resource.
> > One guess is that you are maxing out your connectionpool, so the FDO
> > provider locks up.
> > Another possibility is that your provider is using too many filehandles,
> > and then stops working.
> > For both the possibilities, try limiting the number of connection pool
> > entries in the serverconfig.ini,
> > and see if the problem gets better or worse (raising the limit is likely
> > a bad solution).
> > Regards, Kenneth Skovhede, GEOGRAF A/S
> > durrrr skrev:
> >> Hi,
> >> We are having a great deal of difficulties with the consistency of
> >> layers,
> >> points and searches on our map.
> >> It seems works perfectly 10 times but then suddenly things stop working
> >> such
> >> as search's or suddenly the map wont display at all.
> >> Because these issues are intermittent i can think of no other
> explanation
> >> other than slow network\Server.
> >> Currently we have a map with 55 layers (os, raster, point, line) it is
> >> running on a Windows server using Apache, we have a seperate server for
> >> our
> >> maps and it is being viewed over the internet.
> >> If anyone can help or suggest anything i would appreciate it!
> >> (I am relativly new to the whole mapping development role so simplified
> >> questions are appreciated!)
> >> Thanks in advance
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://n2.nabble.com/Map-Inconsistencies-Is-it-a-Network-Server-Issue-tp3998668p4012377.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091117/4c86cb6e/attachment.html
