[mapguide-users] Map Inconsistencies. Is it a Network\Server
Issue??
durrrr
paul.nicholson at capita.co.uk
Mon Nov 16 09:43:37 EST 2009
Thanks for your reply.
I have added some details from my server setup. Do these numbers look ok?
General Properties
TCP/IP maximum transmission unit: 1460
Connection timeout (seconds): 120
Connection timer interval (seconds): 60
Client Connection Properties
Maximum connections: 100
Maximum queued operations: 40
Maximum threads in pool: 20
Site Connection Properties
Maximum connections: 20
Maximum queued operations: 20
Maximum threads in pool: 10
Thanks
Durrrr
Kenneth Skovhede, GEOGRAF A/S wrote:
> It sounds as if you are exhausting some resource.
> One guess is that you are maxing out your connectionpool, so the FDO
> provider locks up.
> Another possibility is that your provider is using too many filehandles,
> and then stops working.
> For both the possibilities, try limiting the number of connection pool
> entries in the serverconfig.ini,
> and see if the problem gets better or worse (raising the limit is likely
> a bad solution).
> Regards, Kenneth Skovhede, GEOGRAF A/S
> durrrr skrev:
>> Hi,
>> We are having a great deal of difficulties with the consistency of
>> layers,
>> points and searches on our map.
>> It seems works perfectly 10 times but then suddenly things stop working
>> such
>> as search's or suddenly the map wont display at all.
>> Because these issues are intermittent i can think of no other explanation
>> other than slow network\Server.
>> Currently we have a map with 55 layers (os, raster, point, line) it is
>> running on a Windows server using Apache, we have a seperate server for
>> our
>> maps and it is being viewed over the internet.
>> If anyone can help or suggest anything i would appreciate it!
>> (I am relativly new to the whole mapping development role so simplified
>> questions are appreciated!)
>> Thanks in advance
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Map-Inconsistencies-Is-it-a-Network-Server-Issue-tp3998668p4012377.html
