[mapguide-users] Map Inconsistencies. Is it a Network\Server Issue??
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Nov 16 03:24:52 EST 2009
It sounds as if you are exhausting some resource.
One guess is that you are maxing out your connectionpool, so the FDO
provider locks up.
Another possibility is that your provider is using too many filehandles,
and then stops working.
For both the possibilities, try limiting the number of connection pool
entries in the serverconfig.ini,
and see if the problem gets better or worse (raising the limit is likely
a bad solution).
Regards, Kenneth Skovhede, GEOGRAF A/S
durrrr skrev:
> Hi,
> We are having a great deal of difficulties with the consistency of layers,
> points and searches on our map.
> It seems works perfectly 10 times but then suddenly things stop working such
> as search's or suddenly the map wont display at all.
> Because these issues are intermittent i can think of no other explanation
> other than slow network\Server.
> Currently we have a map with 55 layers (os, raster, point, line) it is
> running on a Windows server using Apache, we have a seperate server for our
> maps and it is being viewed over the internet.
> If anyone can help or suggest anything i would appreciate it!
> (I am relativly new to the whole mapping development role so simplified
> questions are appreciated!)
> Thanks in advance
