[mapguide-users] mapguide server crashs even for 5 users
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed Nov 18 05:33:29 EST 2009
You cannot use WinXP as a server.
IIS in WinXP has a limit on the number of allowed connections.
There is a short explanation and a workaround here:
http://www.codinghorror.com/blog/archives/000329.html
Please note that even with the mentioned workaround, you cannot use
WinXP as a server.
You can see that you get the 403 (403.9 actually) errors which usually
indicate "too many connections".
Regards, Kenneth Skovhede, GEOGRAF A/S
sathishpsk9 skrev:
> hi all
> i am using
> mapguide server 2.0(mgos)
> maestro 1.0.9
> .NET framework 2.0
> IIS 5.0
> windows xp professional (sp3)
> king oracle fdo (3.3)
> oracle 10g spatial
> p IV (3.2GHz),512mb ram.
> when i run the application with 5 users ,after 6 th user mapguide server
> crashs.so i tested the application in load runner 9.01 it gave the result as
> follows:
> Analysis Summary Period: 10/11/2009 13:03:03 - 10/11/2009 13:08:54
> Scenario Name: D:\HP\LoadRunner\scenario\Ghazia_10.lrs
> Results in Session: C:\Documents and Settings\srw\Local
> Settings\Temp\res\res.lrr
> Duration: 5 minutes and 51 seconds.
> Statistics Summary
> Maximum Running Vusers:
> 5
> Total Throughput (bytes):
> 28,291,753
> Average Throughput (bytes/second):
> 80,374
> Total Hits:
> 3,729
> Average Hits per Second:
> 10.594 View HTTP Responses Summary
> Total Errors:
> 24
> You can define SLA data using the SLA configuration wizard
> You can analyze transaction behavior using the Analyze Transaction mechanism
> Scenario Behavior Over Time
> The SLA status of the following measurements displayed over time. You can
> select a specific time range for each transaction in order to analyze the
> time range.
> Measurement Name Time Ranges
> Application Under Test Errors 0
> 0
> 0.6
> 0.3
> 0
> 0.2
> 0
> 0
> 0
> 0
> 0
> 0
> 0
> 0
> 0
> 0
> 0
> 0
> 00:00:00 00:00:15 00:00:35 00:00:55 00:01:15 00:01:35 00:01:55 00:02:15
> 00:02:35 00:02:55 00:03:15 00:03:35 00:03:55 00:04:15 00:04:35 00:04:55
> 00:05:15 00:05:35
> Transaction Summary
> Transactions:
> Total Passed: 208 Total Failed: 38 Total Stopped: 0 Average
> Response Time
> Transaction Name SLA Status Minimum Average Maximum Std. Deviation 90
> Percent Pass Fail Stop
> Action_Transaction
> 51.214 60.956 103.222 14.872 95.925 25 19 0
> Home
> 4.077 4.176 4.324 0.083 4.276 27 0 0
> Login
> 12.321 21.342 48.682 10.433 41.326 27 17 0
> maoInfi
> 1.929 2.278 2.818 0.201 2.46 25 2 0
> Map
> 0.028 0.041 0.161 0.026 0.047 25 0 0
> Map1
> 0.007 0.012 0.07 0.013 0.012 25 0 0
> URL
> 0.075 1.936 16.405 5.007 15.645 44 0 0
> vuser_end_Transaction
> 0 0 0 0 0 5 0 0
> vuser_init_Transaction
> 0 0 0 0 0 5 0 0
> Service Level Agreement Legend:
> Pass
> Fail
> No Data
> HTTP Responses Total Per second
> HTTP_200
> 3,260 9.261
> HTTP_302
> 44 0.125
> HTTP_401
> 1 0.003
> HTTP_403
> 309 0.878
> HTTP_404
> 115 0.327
> plz help me...
> sathish
