[mapguide-users] mapguide server crashs even for 5 users
Jason Birch jason at jasonbirch.com
Wed Nov 18 11:45:16 EST 2009
I would recommend trying with MapGuide 2.1.  I was having similar problems
with 2.0.x that almost completely derailed my implementation, though I don't
recall that exact error message.
http://download.osgeo.org/mapguide/releases/2.1.0/MapGuideOpenSource-2.1.0.4283-Final.exe
This build was just uploaded last night and has not been thoroughly tested,
but unless I did something wrong when building the installer it will be the
official 2.1 release.
As mentioned, you will also need to use something other than XP for load
testing; no idea what the behaviour is when the OS starts denying
connections, but it could easily be the cause of this kind of problem.
Jason
2009/11/18 sathishpsk9 <>
> Both Library://thematic/layout.WebLayout  (for thematic viewing  )
> and Library://proptax/layout.WebLayout exist( info search )
> Initially 3 users are accesing the application , and each user is working
> with a different layout.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091118/f9d5d89e/attachment.html
