[mapguide-users] How to add layer to the map on the fly???
MichaelGl michael_gl at stav-gis.com
Tue Nov 24 10:38:29 EST 2009
Actually i have seen some example on PHP,and I wanted to "translate" it to
C#.
So,I don't actually understand the SetLayerDefinition method.
and I don't know how to save "layerdefinition", I didn't found it in MgLayer
object methods.
If I try to change the destination to "Library://Debug/<name>.<type>"
this line :
                 featureService.CreateFeatureSource(resId, sdfParams);
fails.
So,now I stucked.
Kenneth Skovhede, GEOGRAF A/S wrote:
> There is something weird with the variable resId.
> You set it in this line:
> MgResourceIdentifier resId = new MgResourceIdentifier(featureSourceName);
> Then you use it for a layer in this line:
> MgLayer newLayer = new MgLayer(resId, resourceService);
> newLayer.SetLayerDefinition(resId, resourceService);
> That does not explain your error message, but it does not make it easier
> to understand
> the actual problem.
>  From the errormessage I'm guessing that the layerdefinition points to
> the wrong featuresource.
> And you are not saving the layerdefinition?
> The easiest way to debug this would be to change the destination from
> the current
> "Session:<session-id>//<name>.<type>" to
> When your LayerDefinition and FeatureSource are saved in Library,
> you can open them with Maestro/Studio and examine them for errors.
> PS.: "ReadFileAsString" is in the framework:
> System.IO.File.ReadAllText
> http://msdn.microsoft.com/en-us/library/system.io.file.readalltext.aspx
> Regards, Kenneth Skovhede, GEOGRAF A/S
> MichaelGl skrev:
>> Kenneth Skovhede,hi
>> Yes,it is error in the log file :
>>  Error: Resource was not found:
>> Session:c737c35c-ffff-ffff-8000-0025b3b865f4_en_7F0000010AFC0AFB0AFA//TemporaryLines.FeatureSource
>>  StackTrace:
>>   - MgResourceServiceHandler.ProcessOperation line 80 file
>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
>>   - MgOpGetResourceContent.Execute line 120 file
>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\OpGetResourceContent.cpp
>>   - MgServerResourceService.GetResourceContent line 863 file
>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ServerResourceService.cpp
>>   - MgApplicationRepositoryManager.GetResourceContent line 378 file
>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ApplicationRepositoryManager.cpp
>>   - MgResourceDefinitionManager.GetResource line 320 file
>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
>>   - MgResourceContentManager.GetDocument line 590 file
>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ResourceContentManager.cpp
>>   - MgResourceDefinitionManager.GetDocument line 476 file
>> The layer is NOT appear in the legend.
>> I don't really know how to check the signature of the layer and to
>> understand if it looks valid.
>> I'm new user of the MapGuide.
>> So,I'll be really happy if you help me to solve the problem.
>> How can I fix the error from the log file?
>>> What errors do you see?
>>> Are there errors in the log file?
>>> Does the layer appear in the legend?
>>> Does the signature for the layer look valid?
>>> Try saving the temp layer and featuresource in Library:// so you can
>>> examine them from Studio/Maestro.
>>> MichaelGl skrev:
>>>> I'm trying to add temporary layer to the map and I'm fail. Please
>>>> help...
>>>> I have a button :
>>>> <input type="button" value="Start" onclick="DigitizePolygon();">
>>>> This is the client side code :
>>>> <script type="text/javascript">
>>>>     function submitRequest()
>>>>         var pageUrl =
>>>> document.getElementById("hfTargetURL").getAttribute("value");
>>>>         var pointsStr =
>>>> document.getElementById("hfPoints").getAttribute("value");
>>>>         params = new Array(
>>>>                         "SESSION",
>>>> parent.parent.mapFrame.GetSessionId(),
>>>>                         "MAPNAME", parent.parent.mapFrame.GetMapName(),
>>>>                         "POINTS", pointsStr
>>>>         parent.parent.formFrame.Submit(pageUrl, params, "scriptFrame");
>>>>     function DigitizePolygon()
>>>>         var lblBox = document.getElementsByName("lblArea");
>>>>         lblBox[0].innerText = "";
>>>>         parent.parent.mapFrame.DigitizePolygon(OnPolygonDigitized);
>>>>     function OnPolygonDigitized(poly)
>>>>         ShowResults(CalculatePolygonArea(poly));
>>>>     function CalculatePolygonArea(line)
>>>>         var str = "";
>>>>         var res = 0;
>>>>         var tmpInt = 0;
>>>>         var pointsStr = line.Count.toString() + ",";
>>>>         for (var i = (line.Count - 1); i > 0; i--)
>>>>             var currP = line.Point(i);
>>>>             var nextP = line.Point(i - 1);
>>>>             res += ((currP.X * nextP.Y) - (nextP.X * currP.Y));
>>>>             pointsStr += currP.X.toString() + "," + currP.Y.toString()
>>>>             if (i == 1)
>>>>                 pointsStr += nextP.X.toString() + "," +
>>>> nextP.Y.toString();
>>>>         res /= 2;
>>>>         tmpInt = parseInt(res * 100);
>>>>         res = tmpInt / 100;
>>>>         res = (res < 0) ? (res * -1) : res;
>>>>         str = res.toString();
>>>>         document.getElementById("hfPoints").setAttribute("value",
>>>> pointsStr);
>>>>         return str;
>>>>     function ShowResults(res)
>>>>         lblBox[0].innerText = res ;
>>>>         submitRequest();
>>>> </script>
>>>> I'm passing all the points of the digitized polygon to the server
>>>> side,and
>>>> this is the code of the server side
>>>> C# :
>>>> <script runat="server">
>>>>     ArrayList xpts = new ArrayList();
>>>>     ArrayList ypts = new ArrayList();
>>>>     const string templPath = "c:\\Program
>>>> Files\\MapGuideOpenSource2.0\\WebServerExtensions\\www\\viewerfiles\\";
>>>>     protected void Page_Load(object sender, EventArgs e)
>>>>         double centerX, centerY;
>>>>         NameValueCollection requestParams;
>>>>         try
>>>>             //  Initialize and get request parameters
>>>>             InitializeWebTier();
>>>>             requestParams = GetRequestParameters();
>>>>             String mgSessionId = requestParams["SESSION"];
>>>>             String mgLocale = requestParams["LOCALE"];
>>>>             String mgMapName = requestParams["MAPNAME"];
>>>>             string pointsStr = requestParams["POINTS"];
>>>>             string layerName = "Lines";
>>>>             string layerLegendLabel = "New Lines";
>>>>             string groupName = "Analysis";
>>>>             string groupLegendLabel = "Analysis";
>>>>             string featureSourceName = "Session:" + mgSessionId +
>>>> "//TemporaryLines.FeatureSource";
>>>>             BuildPointsLists(pointsStr);
>>>>             //  Connect to the site and create a session
>>>>             MgUserInformation userInfo = new
>>>> MgUserInformation(mgSessionId);
>>>>             MgSiteConnection siteConnection = new MgSiteConnection();
>>>>             siteConnection.Open(userInfo);
>>>>             // Get an instance of the required service.
>>>>             MgResourceService resourceService =
>>>> siteConnection.CreateService(MgServiceType.ResourceService) as
>>>> MgResourceService;
>>>>             MgFeatureService featureService =
>>>> siteConnection.CreateService(MgServiceType.FeatureService) as
>>>> MgFeatureService;
>>>>             //  Initiate the map
>>>>             MgMap map = new MgMap(siteConnection);
>>>>             map.Open(mgMapName);
>>>>             bool featureSourceExists = DoesResourceExist(resId,
>>>> resourceService);
>>>>             if (featureSourceExists == false)
>>>>                 // Create a temporary feature source to draw the lines
>>>> on
>>>>                 // Create a feature class definition for the new
>>>> feature
>>>> source
>>>>                 MgClassDefinition classDefinition = new
>>>> MgClassDefinition();
>>>>                 classDefinition.SetName("Lines");
>>>>                 classDefinition.SetDescription("Lines to display.");
>>>>                 string geometryPropertyName = "SHPGEOM";
>>>> classDefinition.SetDefaultGeometryPropertyName(geometryPropertyName);
>>>>                 // Create an identify property
>>>>                 MgDataPropertyDefinition identityProperty = new
>>>> MgDataPropertyDefinition("KEY");
>>>>                 identityProperty.SetDataType(MgPropertyType.Int32);
>>>>                 identityProperty.SetAutoGeneration(true);
>>>>                 identityProperty.SetReadOnly(true);
>>>>                 // Add the identity property to the class definition
>>>> classDefinition.GetIdentityProperties().Add(identityProperty);
>>>>                 classDefinition.GetProperties().Add(identityProperty);
>>>>                 // Create a name property
>>>>                 MgDataPropertyDefinition nameProperty = new
>>>> MgDataPropertyDefinition("NAME");
>>>>                 nameProperty.SetDataType(MgPropertyType.String);
>>>>                 // Add the name property to the class definition
>>>>                 classDefinition.GetProperties().Add(nameProperty);
>>>>                 // Create a geometry property
>>>>                 MgGeometricPropertyDefinition geometryProperty = new
>>>> MgGeometricPropertyDefinition(geometryPropertyName);
>>>> geometryProperty.SetGeometryTypes(MgFeatureGeometricType.Surface);
>>>>                 // Add the geometry property to the class definition
>>>>                 classDefinition.GetProperties().Add(geometryProperty);
>>>>                 // Create a feature schema
>>>>                 MgFeatureSchema featureSchema = new
>>>> MgFeatureSchema("SHP_Schema", "Line schema");
>>>>                 // Add the feature schema to the class definition
>>>>                 featureSchema.GetClasses().Add(classDefinition);
>>>>                 // Create the feature source
>>>>                 string wkt = map.GetMapSRS();
>>>>                 MgCreateSdfParams sdfParams = new
>>>> MgCreateSdfParams("spatial
>>>> context", wkt, featureSchema);
>>>>             // Add the line to the feature source
>>>>             MgBatchPropertyCollection batchPropertyCollection = new
>>>> MgBatchPropertyCollection();
>>>>             for (int idx = 0; idx < xpts.Count - 1; idx++)
>>>>                 string lineName = "Line " + (idx + 1).ToString();
>>>>                 MgPropertyCollection propertyCollection =
>>>> MakeLine(lineName,
>>>> Convert.ToDouble(xpts[idx]),
>>>> Convert.ToDouble(ypts[idx]),
>>>> Convert.ToDouble(xpts[idx + 1]),
>>>> Convert.ToDouble(ypts[idx + 1]));
>>>>                 batchPropertyCollection.Add(propertyCollection);
>>>>             // Add the batch property collection to the feature source
>>>>             MgInsertFeatures cmd = new MgInsertFeatures(layerName,
>>>> batchPropertyCollection);
>>>>             MgFeatureCommandCollection featureCommandCollection = new
>>>> MgFeatureCommandCollection();
>>>>             featureCommandCollection.Add(cmd);
>>>>             // Execute the "add" commands
>>>>             featureService.UpdateFeatures(resId,
>>>> featureCommandCollection,
>>>> false);
>>>>             bool layerExists = DoesLayerExist(layerName, map);
>>>>             if (layerExists == false)
>>>>                 // Create a new layer which uses that feature source
>>>>                 // Create a line rule to stylize the lines
>>>>                 string ruleLegendLabel = "Lines Rule";
>>>>                 string filter = "";
>>>>                 string color = "FF0000FF";
>>>>                 string lineRule = ReadFileAsString(templPath +
>>>> "linerule.templ");
>>>>                 String[] vals = { ruleLegendLabel, filter, color };
>>>>                 lineRule = Substitute(lineRule, vals);
>>>>                 // Create a line type style
>>>>                 string lineTypeStyle = ReadFileAsString(templPath +
>>>> "linetypestyle.templ");
>>>>                 String[] valsStyle = { lineRule };
>>>>                 lineTypeStyle = Substitute(lineTypeStyle, valsStyle);
>>>>                 // Create a scale range
>>>>                 string minScale = "0";
>>>>                 string maxScale = "1000000000000";
>>>>                 string lineScaleRange = ReadFileAsString(templPath +
>>>> "scalerange.templ");
>>>>                 String[] valsScale = { minScale, maxScale,
>>>> lineTypeStyle
>>>>                 lineScaleRange = Substitute(lineScaleRange, valsScale);
>>>>                 // Create the layer definiton
>>>>                 string featureName = "SHP_Schema:Lines";
>>>>                 string geometry = "SHPGEOM";
>>>>                 string layerDefinition = ReadFileAsString(templPath +
>>>> "layerdefinition.templ");
>>>>                 String[] valsLayerDef = { featureSourceName,
>>>> featureName,
>>>> geometry, lineScaleRange };
>>>>                 layerDefinition = Substitute(layerDefinition,
>>>> valsLayerDef);
>>>>                 // Add the layer to the map
>>>>                 newLayer.SetName(layerName);
>>>>                 newLayer.SetLegendLabel(layerLegendLabel);
>>>>                 // Add the layer to a layer group
>>>>                 MgLayerGroup newGroup = new MgLayerGroup(groupName);
>>>>                 newGroup.SetLegendLabel(layerLegendLabel);
>>>>                 map.GetLayerGroups().Add(newGroup);
>>>>                 map.GetLayers().Insert(0, newLayer);
>>>>             // Turn on the visibility of this layer.
>>>>             // (If the layer does not already exist in the map, it will
>>>> be
>>>> visible by default when it is added.
>>>>             // But if the user has already run this script, he or she
>>>> may
>>>> have set the layer to be invisible.)
>>>>             MgLayerCollection layerCollection = map.GetLayers();
>>>>             if (layerCollection.Contains(layerName))
>>>>                 MgLayerBase linesLayer =
>>>> layerCollection.GetItem(layerName);
>>>>                 linesLayer.SetVisible(true);
>>>>             MgLayerGroupCollection groupCollection =
>>>> map.GetLayerGroups();
>>>>             if (groupCollection.Contains(groupName))
>>>>                 MgLayerGroup analysisGroup =
>>>> groupCollection.GetItem(groupName);
>>>>                 analysisGroup.SetVisible(true);
>>>>             //  Save the map back to the session repository
>>>>             string sessionIdName = "Session:" + mgSessionId + "//" +
>>>> mgMapName + ".Map";
>>>>             MgResourceIdentifier sessionResourceID = new
>>>> MgResourceIdentifier(sessionIdName);
>>>>             sessionResourceID.Validate();
>>>>             map.Save(resourceService, sessionResourceID);
>>>>         catch (Exception ex)
>>>>             Response.Write(ex.Message);
>>>>     void BuildPointsLists(string p_pointsStr)
>>>>         string[] parameters = p_pointsStr.Split(',');
>>>>         int length = Convert.ToInt32(parameters[0]);
>>>>         for (int idx = 1; idx <= (length * 2); idx+=2)
>>>>             xpts.Add(Convert.ToDouble(parameters[idx]));
>>>>             ypts.Add(Convert.ToDouble(parameters[idx + 1]));
>>>>     bool DoesResourceExist(MgResourceIdentifier p_redId,
>>>> MgResourceService
>>>> p_resSrvc)
>>>>     // Returns true if the resource already exists, or false otherwise
>>>>         try
>>>>             p_resSrvc.GetResourceContent(p_redId);
>>>>         catch (MgResourceNotFoundException e)
>>>>            return false;
>>>>         return true;
>>>>     MgPropertyCollection MakeLine(string p_name, double p_x0, double
>>>> p_y0
>>>> double p_x1, double p_y1)
>>>>         MgPropertyCollection propertyCollection = new
>>>> MgPropertyCollection();
>>>>         MgStringProperty nameProperty = new MgStringProperty("NAME",
>>>> p_name);
>>>>         propertyCollection.Add(nameProperty);
>>>>         MgWktReaderWriter wktReaderWriter = new MgWktReaderWriter();
>>>>         MgAgfReaderWriter agfReaderWriter = new MgAgfReaderWriter();
>>>>         string linestring = "LINESTRING XY (" + p_x0.ToString() + " " +
>>>> p_y0.ToString() + ", " +
>>>>             p_x1.ToString() + " " + p_y1.ToString() + ")";
>>>>         MgGeometry geometry = wktReaderWriter.Read(linestring) as
>>>> MgLineString;
>>>>         MgByteReader geometryByteReader =
>>>> agfReaderWriter.Write(geometry);
>>>>         MgGeometryProperty geometryProperty = new
>>>> MgGeometryProperty("SHPGEOM", geometryByteReader);
>>>>         propertyCollection.Add(geometryProperty);
>>>>         return propertyCollection;
>>>>     bool DoesLayerExist(string p_layerName, MgMap p_map)
>>>>     // Returns true if the layer already exists, or false otherwise
>>>>         MgLayerCollection layerCollection = p_map.GetLayers();
>>>>         return (layerCollection.Contains(p_layerName) ? true : false);
>>>>     string ReadFileAsString(string p_fName)
>>>>         string sContents = string.Empty;
>>>>         System.IO.StreamReader sr = new
>>>> System.IO.StreamReader(p_fName);
>>>>         sContents = sr.ReadToEnd();
>>>>         sr.Close();
>>>>         return sContents;
>>>>     String Substitute(String templ, String[] vals)
>>>>         StringBuilder res = new StringBuilder();
>>>>         int index = 0, val = 0;
>>>>         bool found;
>>>>         do
>>>>             found = false;
>>>>             int i = templ.IndexOf('%', index);
>>>>             if (i != -1)
>>>>                 found = true;
>>>>                 res.Append(templ.Substring(index, i - index));
>>>>                 if (i < templ.Length - 1)
>>>>                     if (templ[i + 1] == '%')
>>>>                         res.Append('%');
>>>>                     else if (templ[i + 1] == 's')
>>>>                         res.Append(vals[val++]);
>>>>                     else
>>>>                         res.Append('@');    //add a character illegal
>>>> in
>>>> jscript so we know the template was incorrect
>>>>                     index = i + 2;
>>>>         } while (found);
>>>>         res.Append(templ.Substring(index));
>>>>         return res.ToString();
>>>> </script>
>>>>     function OnPageLoad()
>>>>         parent.mapFrame.Refresh();
>>>> </script>
>>>> The problem is that the polygon is not appear on the map. What am I
>>>> missing???
>>>> Thanks a lot.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/How-to-add-layer-to-the-map-on-the-fly-tp4031367p4058591.html
