[mapguide-users] Failed to stylize layer
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed Nov 25 03:46:21 EST 2009
MapGuide OS 2.1 now uses the Mentor coordinate system library,
where PROJ.4 was used previously.
I'm guessing that the ecw is reporting a projection that is compatible with
PROJ.4 but fails for Mentor for some reason.
Regards, Kenneth Skovhede, GEOGRAF A/S
Jose Cerrejon skrev:
> I met this error long time ago. Now I need server a .ecw raster file with the
> WMS Mapguide Server.
> But the error.log show me this:
> Error: Failed to stylize layer: VoltiosDemo/Layers/21044_Raster
> The coordinate system initialization failed.
> Could not initialize the geodetic transformation.
> The .ecw file has the correct CS (EPSG:23029) and I fill this in with Studio
> or Maestro (WMS Tab > SRS)
> So what's wrong?
> Note: I'll tried to serve a .shp file with Mapguide WMS Server and works.
> Mapguide OS 2.1 Final + WinXP + IIS + PHP + qGIS or Acad 2010 to load WMS
> from Mapguide Server.
