[mapguide-users] Failed to stylize layer
Jose Cerrejon
gis at mapas-sll.com
Wed Nov 25 03:51:39 EST 2009
Thanks for your answer, Kenneth, it's a honor.
The problem was that the .ecw has Coord. System XY-M Arbitrary.
With Mapguide Studio 2009, I've changed to the coord. I want (EPSG:23029 =
SPAIN; UTM Zone 29).
Solved!
Kenneth Skovhede, GEOGRAF A/S wrote:
> MapGuide OS 2.1 now uses the Mentor coordinate system library,
> where PROJ.4 was used previously.
> I'm guessing that the ecw is reporting a projection that is compatible
> with
> PROJ.4 but fails for Mentor for some reason.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Jose Cerrejon skrev:
>> I met this error long time ago. Now I need server a .ecw raster file with
>> the
>> WMS Mapguide Server.
>> But the error.log show me this:
>> Error: Failed to stylize layer: VoltiosDemo/Layers/21044_Raster
>> The coordinate system initialization failed.
>> Could not initialize the geodetic transformation.
>> The .ecw file has the correct CS (EPSG:23029) and I fill this in with
>> Studio
>> or Maestro (WMS Tab > SRS)
>> So what's wrong?
>> Note: I'll tried to serve a .shp file with Mapguide WMS Server and works.
>> Mapguide OS 2.1 Final + WinXP + IIS + PHP + qGIS or Acad 2010 to load WMS
>> from Mapguide Server.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Failed-to-stylize-layer-tp4059195p4063679.html
