[mapguide-users] IIS crashes with ver 2.1
isca
mapguide2007 at gmail.com
Sat Nov 28 08:00:00 EST 2009
Hello,
a workaround is to disable rapid fail protection in IIS. The worker process
will still crash but the user will not notice it. It was already a problem
with previous versions of MapGuide.
shaharlevy wrote:
> Hello,
> I use ver 2.1-final on Windows serevr 2003, IIS 6, and my IIS crash.
> I think its something with the Application pool i get w3wp.exe error?
> also i got many other error :
> 1.
> Event Type: Error
> Event Source: MapGuide Server v2.1
> Event Category: None
> Event ID: 0
> Date: 26/11/2009
> Time: 15:14:37
> User: N/A
> Computer: GIS-APP-YAK
> Description:
> The description for Event ID ( 0 ) in Source ( MapGuide Server v2.1 )
> cannot be found. The local computer may not have the necessary registry
> information or message DLL files to display messages from a remote
> computer. You may be able to use the /AUXSOURCE= flag to retrieve this
> description; see Help and Support for details. The following information
> is part of the event: Port 2811 is not available, please try using a
> different port.
> 2.
> Event Type: Information
> Event Source: W3SVC
> Event ID: 1074
> Date: 26/11/2009
> Time: 09:17:51
> User: N/A
> Description:
> A worker process with process id of '7024' serving application pool
> 'MapGuideAppPool' has requested a recycle because the worker process
> reached its allowed processing time limit.
> For more information, see Help and Support Center at
> http://go.microsoft.com/fwlink/events.asp.
> 3.
> - MgMappingUtil.StylizeLayers() line 776 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\mapping\MappingUtil.cpp
> <2009-11-27T07:06:14> 7900 Ajax Viewer 8.200.7.22 Administrator
> Error: Failed to stylize layer: BBISPLinksIP
> An unclassified exception occurred.
> Any help is much appreciated.
> Thanks,
> Shahar Levy
> Shahar
View this message in context: http://n2.nabble.com/IIS-crashes-with-ver-2-1-tp4077072p4079436.html
